Old 04-16-2014, 03:13 PM
SpeedyE SpeedyE is offline
Mein Auto: 2011/335i
Can you damage your suspension at the racetrack?
I signed up for a SCCA trackday. I want to learn how to drive this car and what it does when you go past the limit.
I race at this track, and am a race school instructor there as well (motorcycles) so I anticipe I will be going pretty fast and heating up the shocks.
Question:
Factory OEM suspension on motorcycles can be destroyed very quickly on a racetrack from overheating the oil, etc.
Racing suspension needs to be refreshed 1-3 times a year in motorcycle racing.
Will pressing the OEM suspension on a BMW on the track cause any issues ie: causing preload/compression/rebound/oil issue down the road....will it wear it out?
This is a one time deal, will never take it to the racetrack again.
Thanks for any advice
car is a 335i w/ sport suspension
2011 335i Sport/Premium/cold. Black-on-Black, Jack I LOVE this frickin' car!!!!
2007 Suzuki GSXR1000 WERA/CCS SS-spec race bike
Old 04-16-2014, 03:34 PM
Nerdboss Nerdboss is offline
Mein Auto: 2011 328i
I've never heard of such a thing. It's a BMW, it's made to go fast. Enjoy it
2011 328i | Jet Black | Oyster/black Dakota | Navigation | Premium package | Sport Package | Heated seats
Old 04-16-2014, 04:03 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
If you go "past the limit", you may wreck the car, thereby destroying the suspension
Kidding aside, I think if your suspension is in good condition to start, there shouldn't be many issues aside from increased wear. If you had some bushings that were on their way out, there could be some abnormal wear from their lack of availability to control the suspension geometry. Same goes for worn shocks.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 04-16-2014, 04:12 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
Question:
I wouldn't worry about it unless you try and redesign your car like I did.
I had applied "stiffer" anti-roll bars to my former E46 M3 (Eibach installed them at their facility). After 2 - 3 BMW CCA driving schools they (rear) tore through the mounting brackets which had to be re-welded.
I should have left the car as it was (but, geez that car was tight in corners).
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 04-16-2014, 08:04 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Question:
OK....all right....dude, you're toast!
One good run without auxiliary shock cooling will cause your oil to lose so much viscosity and lubricity that your suspension could seize!
Here's what you do: Wrap each rear shock and front end strut w/cold packs, available at any Rite Aid. Yes. Use wire ties and elastic bandage. Then rip it, and rip it! But please, observe the time specification on the packs you buy - exceed that limit and all is for naught!
NOTE: Ambient temps greatly change effective cold pack use times - consult the manufacturer of your product about your application.
Old 04-17-2014, 04:57 AM
Mein Auto: '06 AW 330xi
You'll be fine. Though you may want better brake pads and fluid at the very least.
Old 04-17-2014, 05:42 AM
I bought dry-ice and zip ties....and got a new perm, I am good to go...
Old 04-17-2014, 06:07 AM
Mark K Mark K is offline
Mein Auto: '17 GTI '16 981 CS
I will second the serious advice to change brake fluid - and that's it. Believe me, your tires will fly a surrender flag way before your suspension even realizes you are on a racetrack
If this is the one and the ONLY time you will drive that car on the track, brake fluid and that's it. Save your money and don't worry about suspension.
I just had (yesterday) tire shop mount 4 slicks on my ex winter wheels. First time on slicks ever - if my instructor agrees on it. Apr 26th on Mid-Ohio. Can't wait ...
_
2017 Golf GTI |Silver over tartan cloth| MT| Base S, no options. Oh, wait! ... It does have a spare tire!
2016 981 Cayman S | 6-speed MT| Active suspension | Sport Exhaust System | Torque vectoring (with LSD) | Sport seats + | Sport design steering wheel
2013 VW Golf TDI [CONFISCATED]
2011 E92 335i 6MT ZSP ZCW (ED May 17th 2010) [SOLD]
Old 04-17-2014, 06:24 AM
///M-Furby's Avatar
///M-Furby ///M-Furby is offline
IntarWeb Stalker
Mein Auto: 2016 M3 SO ZCP
Stop giving him half-arsed advice Cal. Because of you he might jeopardize his suspension.
@OP -> What Cal maliciously neglected to mention is that you do not apply the ice before the race. You need to apply the ice IMMEDIATELY after the race. As long as the shocks are at the highest temperatures then the quick cool-down will help stabilize any issues.
"Tomato" ED 2016 M3 | B50 | ZCP | X3SW | ZDB | ZEC | ZLP | 2MK | 5DP | 6NS |
"Booberry" ED 2013 335xi | Returned
"Boo" CPO 2006 330xi | Sold
My Drive Style
Because I can.
Originally Posted by cwinter View Post
I agree with furby
Originally Posted by guerilla twang View Post
Hahahaha, I like you furb, you like to live dangerously.
Originally Posted by ProfessorCook View Post
I started to google to find a picture to match furby's suggestion to Gia, but it quickly became clear it was an inappropriate search to conduct at work.
Old 04-17-2014, 06:57 AM
Furb, if one employs post race reactive technique, you should mention Nomex. Yes. Any track pilot annealing red hot shocks must, according to NASCAR regulation, wear full body Nomex.
I lean toward proactive technique - active cold packs - yields better damping and does not require Nomex.
Old 04-17-2014, 08:33 AM
I am covered!
Heating pads from Walmart, already purchased.
Velcro'd on w/ kite string attached, and routed to my cockpit...once I have my warm-up lap in, I yank the strings and off come the heat-pads....easy as that!
I still haven't figured out how to mechanically transition to my dry-ice packs....I may wrap instant-cold-packs around the springs, underneath the warmers, and then hit the rumble-strips hard to mix the cold packs and cool the susp down.
I'mma wear a swimmers cap to keep my perm aerodynamic
Old 04-17-2014, 08:35 AM
That's overkill.
Harley Davidson beanie-helmet, and leatherette fingerless gloves keep me safe and stunning at the same time
Old 04-17-2014, 08:38 AM
If I pack the inside of my tires w/ dry-ice right before the trackday, will the coldness work it's way (dissipate) to the suspension(?), or am I creating other issues, like taking the chance of over-cooling my brake pads?
Old 04-17-2014, 08:56 AM
thekurgan's Avatar
Bad Lieutenant
NO! Fill tires with nitrogen
Ilse
Bruna
BMWCCA #453648
Old 04-17-2014, 09:09 AM
pointandgo's Avatar
Shirley you jest.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
Member: BMW CCA
Old 04-17-2014, 10:15 AM
That's overkill.
A fashion statement, it must be said. I wear Crank Brothers leather, but fingerless gloves may not be optimal après hot laps!
May I recommend a fire extinguisher? CO2 preferred to foam, and listen for the satisfying crack and pop of cooling struts & shocks. Engulfing cloud of vapor draws ooohs & ahhhs!
Old 04-17-2014, 10:50 AM
DozerDan DozerDan is offline
Mein Auto: 335 d
I would laugh you off the track if you showed up with ice packs on your shocks.
Just stop over thinking it and go drive the car. You are not running a 24hr race here. Fire suits for the most part are a sham, your basic suit has a 3 second burn rating, more for a flash over than anything else. Shy of spending big dollars they are not worth much other than when they are 'required'
Fill the tires to proper inflation, make sure your brakes are in good shape and run it.
Old 04-17-2014, 11:43 AM
I challenge you to find a more handsome pair of racetrack gloves.
The unparallel'd dexterity is reason alone to champion this glove....dexterity equates to feedback which equates to lower lap times. Not to mention their rugged, yet gentlemanly look.
Form follows function, but when the planets align, you have both.... these gloves are a miracle of racing prowess.
Old 04-17-2014, 11:44 AM
captainaudio's Avatar
Worlds Foremost Authority
Unless you engage in an off track excursion your suspension will likely take less of a beating on the track than it does on public roads. On the track you are not going to encounter pot holes, frost heaves, construction plates, etc.
You are far more likely to damage a track car on the street than a street car on the track.
CA
Drivers Club at Lime Rock
BMWCCA
Cayman Club Nor'Easters
Porsche Club of America
Sports Car Club of America
American Mural Project
Mount Washington Observatory
Old 04-17-2014, 11:47 AM
Yes....until I set a new lap record, due to innovative, out of the box thinking!
We shall see who is laughing last.
Old 04-17-2014, 11:48 AM
Normally, you want to over inflate your STREET tires by a few psi for a track day. Slicks, inflate to normal pressure.
Old 04-17-2014, 11:55 AM
///MyLittlePony's Avatar
///MyLittlePony ///MyLittlePony is offline
Outside looking in
Mein Auto: 2015 Mustang GT
Huh? Really?
My Little Pony
Old 04-17-2014, 11:56 AM
Outside looking in
CA
You haven't run the LRP skid pad or auto-X course recently then?
My Little Pony
Old 04-17-2014, 12:14 PM
Outside looking in
OP - you'll be fine. As stated, make sure you have new brake fluid and plenty of pad left before starting. Also, take a tire pressure gauge to monitor the pressure after the session. You probably want to be about 40psi HOT to get the most grip out of your tires. This accounts for the softening of the compound when hot. For me in my M3, this equates to 32psi before the first session, but you'll have to figure this out for your car/driving. If you overinflate as suggested (done in auto-x to help the car move around in tight corners), you will have a very small contact patch, limited grip very quickly and risk cording the middle of the tread by the end of the day. If you don't believe me try it. If you don't have a torque wrench, you will be able to borrow one.
My Little Pony
Old 04-17-2014, 12:43 PM
Conundrum...
I mounted my wheels to a lathe and cut the treads off of my street tires
Now they are street compound slicks.
Should I run a psi in between over-inflated & normal?
