Old 04-16-2014, 05:47 PM
PhilK606 PhilK606 is offline
Mein Auto: 07 X3. 14 328i
Transmission DOA at 67K ?
We were just diagnosed with a shot transmission in our 07 X3. Last week the car ran absolutely fine one day and then would not move the next, when put in drive the motor seemed to lug down a little but car would not go. Had it towed into the local foreign repair shop were it was diagnosed as a "broken gear selector shaft" something he had never seen before in all his years of working on BMWs and neither had the transmission shop he sends his rebuilds to. So he suggests we send it to the dealer and maybe BMW of NA will help out with the cost because although not unheard of it is very rare and another tip off was the replacement part was an upgrade. Not a direct replacement . Well today I heard from the dealer the tranny is trash - multiple codes (6 I think in all) $7000 job but they'll do it for 6.k. I'm in shock n awe! Spoke to my original mechanic again and he says all the other codes relate back to the "broken gear selector shaft" and that is explained at the bottom of the tech bulletin. What do I do? We just bought this car last fall and all service etc was up to date and we had it checked out and serviced by the dealer we bought it from. Help
Old 04-16-2014, 09:10 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Find bullet; bite hard.
It is rare - did anyone look inside?
Old 04-16-2014, 09:53 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
Find a good INDY and see if they can get a used tranny to install. Should be half that cost and they will usually warranty them up to a year. This is what I found for my car:
http://www.autopartsfair.com/bmw-use...2f0&seq_num=10
Old 04-17-2014, 05:04 AM
Banned
Mein Auto: 2007-335 HTC
thats why you always purchase an extended warranty for these (expensive to fix) cars
Old 04-17-2014, 06:57 AM
David1's Avatar
David1 David1 is offline
Mein Auto: 07 X3 and 335i
Find a used tranny and get it installed. That's about all you can do. Up to date service does not mean much on any car. You can not prevent a catastrophic mechanical failure. Just luck of the draw.
2017 M2 - Alpine White - Black/Blue Dakota | DCT | Executive Package
2009 335i Coupe - LBM - Black Dakota/Glacier aluminum - 6spd | Nav | M-Sport | Premium | Logic7 | Heated Seats | CA |BMW Performance Suspension/M3 control arms| Sold
2009 X5 3.0 - Sold
07 X3 - Sold
07 335 coupe - sold
Old 04-17-2014, 11:26 AM
No one has actually looked at the inside (so far). That is part of my question(s) - and I do hope this does not sound like one of those gripe threads. What I want help with is education and strategy. From looking around here I gather this is GM built transmission and that they are in lots of cars, but are they just to sophisticated to work on outside the factory? Or is this type of failure akin to a broken timing belt where (some) motors basically beat themselves to pieces before we can even react, if you'll forgive a poor analogy? We did gamble when we chose to forgo the extended warranty and that's "water under the bridge" now, however I still feel this is a keeper car, and I want it repaired right. BMW NA is talking to the dealership and asked us give them 3 days to process things. Thank you for your suggestions and the link to the reman trans too. To be continued.
Old 04-17-2014, 11:56 AM
SuperTerp SuperTerp is offline
Mein Auto: m4now M5M3 550 760 335RIP
I'd ask BMW NA if they could help you get some kind of leniency especially if you bought it from one of their dealers lots of people have gotten help from them maybe 5k instead of 7 installed or something I have no idea...
Sorry to hear about it bro..
Old 04-17-2014, 12:55 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
FWIW, my indie has had to rebuild a lot of the X series transmissions around 50k. He doesn't feel they are nearly as durable as they should be.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 04-17-2014, 04:33 PM
Thanks again for any info and "schooling"
Old 04-17-2014, 07:53 PM
fun2drive's Avatar
BMWCCA 149159
Typically I do recommend draining the pan and pulling it to replace the filter but not at 50K miles.
Failure to change your AFT would not cause this type of failure if it turns out to be a failed gear. Failed gears fail because of a flaw which becomes a stress crack and then eventually fails. Nothing you can do about that.
I would suggest that while you are getting this resolved you change your diffs and transfer case fluid too. The transfer case is the most important system for making the car operate. It only holds 0.6L of BMW special fluid. It costs 70 bucks for a L of the stuff and you can get two changes out of that one L because you can only drain 0.5L out.
Failure of the transfer case is more common at 100K miles and expensive as well.
As Hondo mentioned you can get an extended warranty but it will not cover this failure but would cover the car in the future.
I have never found extended warranties useful when buying new but might be a good idea if buying CPO or used.
I hope that BMW NA and the dealer consider good will because you didn't cause this to fail. It missed quality control when happens from time to time.
Good luck and please post what happens and how you resolve this problem...
Old 04-18-2014, 05:16 AM
Hey, you're looking for answers.
So. Look inside - every diagnosis must be confirmed. Involves dropping the valve body; taking peek.
Old 04-18-2014, 06:14 AM
sunny5280 sunny5280 is offline
Mein Auto: 2011 X5-M
I'd wait to see what BMW NA has to say. They ended up covering part of the cost for an out of warranty repair on my X5.
Old 04-18-2014, 07:40 AM
rdkind62's Avatar
rdkind62 rdkind62 is online now
Mein Auto: 2011 BMW 335is, 2015 X1
I think I would be looking into getting a rebuilt/used transmission from another source. I think if you go to BMWNA and they do happen to offer assistance then it will still be more expensive than going the alternative route.
BMW 335is, Cobb tune with VRSF intercooler, Injen CAI, and BMS downpipes. 382/414 rwhp/tq. Le Mans blue with Black Dakota leather, Convenience and Premium packages, 19" wheels, 7 speed DCT, heated seats, Nav., Harmon Kardon Logic 7 stereo w/ Satellite radio. 2015 BMW X1 28iXdrive M Sport, LeMans Blue, with Black Dakota leather, Premium and Technology packages, with heated seats, satellite radio.
Old 04-18-2014, 09:16 AM
coldfinger coldfinger is offline
Feelin' Bimmee..
Mein Auto: 2006 330i
Must be rare..same thing happened to my wife's 07 X3. Exactly the same mileage! Wouldn't go into reverse. It was a year ago.
Didn't even waste my time calling BMW NA. Went to a tranny shop and they found me a used one with low clicks and put it in.
Think it was around 4k?
NICE.
2006 BMW 330i Black/Black Navi Sports Package 18" wheels
2007 BMW X3 White/Gray Navi M-Package 19" wheels
Old 04-18-2014, 09:36 AM
NICE.
Curious: Why would you not take the time to give them a call? While it's unlikely they would have helped you one never knows if they don't ask.
Old 04-18-2014, 10:18 AM
BashedBarrique's Avatar
BashedBarrique BashedBarrique is offline
Mein Auto: 2006 325i
...the car ran absolutely fine one day and then would not move the next...
Sorry to hear about your misfortune and I know this won't help you in your current dilema, but...
This is one reason I avoid automatic transmissions. I have never had a manual transmission that worked perfectly one day and then wouldn't even move the next day. I have seen many automatics suddenly fail with no warning.
The only problems I have ever experienced in over 30 years of owning and driving 18 manual transmission vehicles is worn clutches, and crunchy synchronizers. The worn clutches were in cars that I bought used and had been worn by previous owners inept shifting skills and the synchros were usually as a result of years of aggressive shifts.
Both problems gave plenty of warning (usually years) before they became serious issues.
The only time a manual transmission car had an out of the blue failure was a 1979 Ford Fiesta that suffered a snapped clutch cable. I was still able to start the car in first gear and drive it home by shifting with out using the clutch. And I bought the part for $80 and replaced it in about 30 minutes.
Automatic transmissions are from the devil.
Old 04-18-2014, 10:27 AM
Oh, I also had a 1969 Mach I that would "pop" out of 4th gear if you lifted off the throttle quickly. You just had to push it back into gear and to be fair it was a tired old drag car that had lived a hard life, one quarter mile at a time.
Now that I have gone off topic, let me get back on by seconding the suggestion of first asking the dealer for help (and when that doesn't work) then having an indy install a used, low mileage, transmission.
Old 04-19-2014, 12:42 AM
sptt144's Avatar
Maybe you never learned how to properly drive an automatic transmission then? They are pretty darned reliable and I would take an automatic any day over a manual that I know I will have to spend $$$ on shortly to repair like many I have known have had to do.
Old 04-19-2014, 06:34 AM
Originally Posted by sptt144 View Post
Maybe you never learned how to properly drive and automatic transmission then? They are pretty darned reliable and I would take an automatic any day over a manual that I know i will have to spend $$$ on shortly to repair like many I have known have had to do.
Do a little research and you will see that manual transmissions are far less likely to have problems and the problems are less expensive when they do occur.
It's common sense.
Automatic transmissions are MUCH more complicated devices. A manual transmission is basically a box with a couple of shafts with gears on them. Automatic transmissions have planetary gears, fluid couplers, complex hydraulics, computerized electronic controls, coolant lines etc.
Old 04-19-2014, 09:56 PM
sptt144's Avatar
It's common sense.
LMAO...I can't believe someone actually responded! OK...I will do a little research....lol!!!
Old 04-22-2014, 08:00 PM
Last Friday I was faced with having to replace the transmission, the question seemed to be reman or used. BMW NA agreed to pay half on the repair but off "warranty" price list. My half was going to be $4100. My Indy said all he could get me was a used one (remans are only available thru dealership , didn't know that) would probably total about $2000. Later that afternoon the service mgr put the car inside and "looked inside" as my new friend Calwaterboy suggested. The gear selector shaft was not broken, but there was no pressure so they went after the pump. That's when they found the "gear selector valve" was blown up - would not hold fluid - so no pressure, no engaging or changing gears. The part was available and cost $29.93. The mechanic came in Saturday and put it in and back together etc. Final cost with oil pan gasket, filter, new fluid, labor and shop charges was just under $1000. Picked car up yesterday and it seems to be its old self again, shifts fine, maybe a little spunkier! A grand is not cheap to me but compared to what we've been talking about, I'm one happy and lucky and very appreciative fellow. Wish you all were here so I could buy you a beer Prost!
Old 04-22-2014, 08:16 PM
A very smart guy, and possibly the best pol in a particular office in several generations, once said: "Trust, but verify." He was talking about those wasskilly Wussians....and isn't it a dang shame the Socialist didn't take that advice?
Whelp, you did, and look what it got you....yessir, self reliance ain't never gettin' old!
Old 04-22-2014, 09:56 PM
Hey, that's great!
I hope that puts your trans back in business for the next 200,000 miles.
Make mine an Augustiner Brau Munchen Dark.
Old 04-22-2014, 11:55 PM
sptt144's Avatar
That is actually great news! BMW could have still gone on and swapped out the transmission and charged you bigtime but the tech was honest as one would hope and found the actual issue. I would be relieved to pay $1K in your situation. Congrats on pursuing what you could anyway on your end. Helps us all.
Old 04-23-2014, 04:57 AM
Banned
If I had the same problem and took it to the BMW place and all they said (with out investigating the issue) is put a new transmission in the car, I would tow it somewhere else,
thats like saying your tire pressure monitor system came on, we must replace all 4 tires!
