Old 04-17-2014, 12:36 PM
mira4581 mira4581 is offline
Mein Auto: 328i xdrive
Clutch Help 328xi
Hey guys, I have a clutch problem on my 2010 328xi 58k and wondering what you all think. The car drives ok in 1st and 2nd gears but when I switch into 3rd, 4th etc after 3000 rpm it jumps to about 6000 rpm and slowly accelerates while rpm drop to around 4000 before going up. It feels like the clutch is skipping then engages back or similar to burning out in the rain when rpmís jump and go back down when the tires finally grip the road. Does that sound like the clutch is going out or maybe a master cylinder? Itís strange to me that its working in 1st and 2nd gears. BTW I am a 2nd owner and haven't had the car much so I donít know if the prior owner drove it properly.
Old 04-17-2014, 12:51 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Sounds strange to be slippage is 1st -> 2nd works without any issue. How is 1st to 2nd with higher rpm, similar to your 3rd, 4th scenario? Do you know the maintenance record? Clutch bleeding? Was the lock valve removed perhaps?
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 04-17-2014, 12:57 PM
Its not slipping in 1st or 2nd even at higher rpm's. I don't know what kind of maitance was done on it. Trying to figure out where to start looking other then taking it in.
Old 04-17-2014, 01:57 PM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
Your clutch is slipping for sure. You need a new one.
Old 04-24-2014, 07:27 PM
Thanks, yes it was the clutch. I had it replaced today and it was in terrible shape, even started cracking in the middle. I took the car to Alex's Auto Shop ( http://www.alexshopinc.com/ ) , great guys , specialize in German cars. They gave me the best price, highly recommend for anyone in Orlando.
