Old 04-17-2014, 03:43 PM
Banned
Mein Auto: 2007-335 HTC
335 convertible rear window seal
was cleaning my 2007 335 convertible, the rear window has a rubber gasket on the lower edge of the window its like about 1/4 inch wide, it doesnt make the window to body seal just a rubber lip, it appears its glued to the window and mine has come loose an area about 3 to 4 inches long, any idea how to reattach?
thanks
Old 04-17-2014, 03:49 PM
Mein Auto: '06 AW 330xi
Post a picture. If you're talking about the metal trim, you'll need to pull out the seal, then install the trim, then re-install the assembly.
However, removing the seal almost always damages them. So you may want to have a spare on hand.
Old 04-18-2014, 03:57 AM
Banned
yes I will have to post a pic, its not the metal seal, where the rear window bottom meets the trunk deck, there is a small rubber strip that appears that is glued to the underside of the rear window, thats the part I am talking about
Old 04-18-2014, 04:01 AM
Banned
to make is easy, go to Kats sticky on Keeping your top in shape, scroll down to where the top pics start, in the 3 pic look at the 2 blue arrows on the right side of the of the pic that say don't forget about this seal, thats the rubber seal I am talking about
