Old 04-22-2014, 09:59 AM
71Tuxedo 71Tuxedo is offline
Mein Auto: 2008 335xi
Error Code P0036 Part Number
Hi All - I did my obligatory searches but came up empty on my specific error code P0036. My Service Engine Soon light came on and threw this code after I had some repairs done, which involved taking the exhaust down. P0036 came back as HO2S Heater Control Curcuit (Bank 1, Sensor 2). I'm a DIY guy and I'm trying to research 1. what the actual part number is and price, and 2. if there are any tips or visual aids out there for replacing these sensors.
This is for a stock 2008 335xi.
Thanks in advance!
Old 04-22-2014, 10:05 AM
Mein Auto: '06 AW 330xi
The heater circuit in your O2 sensor is shot. You need a new sensor.
Location is bank 1, sensor 2 which means it's a post cat sensor used to monitor cat efficiency.
It's not urgent you replace this sensor. It is an emissions related system and is not used by the DME for anything other than measure cat efficiency. The pre-cat sensors are the important ones than will measure A/F ratios, rich and lean conditions, etc
Use realoem.com to find part #s. Then enter the part # into a parts seller like getbmwparts.com or ecstuning.com
You'll need to get under the car to access these as well as remove the splash shields. You should be able to get to them without removing much else but it may be a tight space.
Be careful with the wiring harness as they can break easily. Don't bend it too much
Old 04-22-2014, 10:47 AM
Thanks much fdriller! Great info. I think I found the part numbers, so I just need to make sure I pull the correct one... post cat, abnd each have different lengths. Looks like it's going to run about $216.
