Old 04-22-2014, 10:08 AM
scotydnt scotydnt is offline
Mein Auto: 2011 335i
Air conditioner surging
Need some advice. I have a 2011 335i. With the AC on and at low fan speed it sounds like the blower motor is increasing speed for a couple seconds then decreases for a couple seconds and keeps repeating the process. With the AC off the surging stops. Also, the other settings do not matter ie re circulation, auto, temp setting... Has anyone else heard of this issue? If so, is it an issue or normal operations? Thanks
Old 04-22-2014, 10:11 AM
Mein Auto: '06 AW 330xi
What is surging?
The air flow out of the vents?
Or the compressor/engine?
Old 04-22-2014, 10:13 AM
Air flow from the vents. Definitely not an engine issue
Old 04-22-2014, 11:05 AM
birdman15 birdman15 is offline
new to BMW life
Mein Auto: 2008 328xi
low refrigerant in the a/c system sounds like. The compressor kicking on & off.
Old 04-22-2014, 11:18 AM
White94RX White94RX is offline
Mein Auto: E39 540
The compressor cycling has nothing to do with the blower motor
BMW Level 1 Master Certified
2001 BMW 540i
Old 04-22-2014, 11:21 AM
new to BMW life
not saying it does BUT with the A/C off he says the surging stops..........
Old 04-22-2014, 11:24 AM
If the refrigerant was low wouldn't the AC shut down?
Old 04-22-2014, 11:26 AM
new to BMW life
no it would build pressure cycle then kick out when pressure drops.
Old 04-22-2014, 11:37 AM
Worth a shot. I would prefer servicing the system vs. finding a bad sensor or actuator
Old 04-22-2014, 11:44 AM
It's very common for the blower motor bearings to rust and the motor seizes. Sounds like yours is about to seize.
Check you windshield cowl cover. Is there a gap between the glass and be rubber seal?
If so, fix the cowl first. A leaking cowl will allow water to drop onto the blower motor, accelerating the failure rate.
Most of the time, you can dissemble the motor and remove the rust, grease the bearings and shaft, then reinstall.
Old 04-22-2014, 12:05 PM
wilt wilt is offline
Mein Auto: 2011 328i
It could also be that the temperature sensor is unstable, causing the system to think it needs to blow more air in to cool the interior to the desired temperature, then it thinks it is cool enough and slows the fan, before again deciding it needs to ramp up the fan speed.
Old 04-22-2014, 12:06 PM
Ok. If I have a fouled motor wouldn't the surge happen all the time, not just when the AC is on?
Old 04-22-2014, 12:12 PM
From what I've seen there are at least two temp sensors. Is there a way to check if one is bad or just swap in a new one and see what happens?
Old 04-22-2014, 02:05 PM
Ohh I thought you meant that it stops when you turn off the entire system, not just the AC.
Old 04-22-2014, 02:26 PM
mossman35 mossman35 is offline
Mein Auto: 2016 340 Xdrive Msport
Does it do this in relation to vehicle speed? Our cars increase fan speed with vehicle speed. It's in the manual. If it has nothing to do with vehicle speed, then must be something mentioned above.
Old 04-22-2014, 02:37 PM
Now that you mention it, I've only noticed in stop and go traffic(slow/stop). Also it doesn't increase with my relative speed, it surges on it's own no matter if I'm going slow or stopped. Not sure if it happens when I'm on the interstate. If it changes with vehicle speed do I need to look in a different place? Also by fan speed to you mean the fan on the radiator or the blower motor?
Old 04-22-2014, 02:46 PM
Now that you mention it, I only noticed in stop and go traffic(slow/stop). Also it doesn't increase with my relative speed, it surges on it's own no matter if I'm going slow or stopped. Not sure if it happens when I'm on the interstate. If it changes with vehicle speed do I need to look in a different place? Also by fan speed to you mean the fan on the radiator or the blower motor?
By fan speed, I mean the blower speed. The car compensates for pressure differences at speed. So... as you speed up, you will get more air blowing into the cabin. It's not really noticeable until it's warm outside and the dash vents are being used more.
It's one of those things where once you notice it, it's hard not to notice it. I notice it much more on sunny warm days when I am in stop and go traffic.
If it is this, it shouldn't "surge" at a constant speed.
Old 04-22-2014, 03:04 PM
Aaahhh ok I know what you're talking about. Yeah that happens as well. Much more noticeable the faster the blower motor is going. I figured it was to aid in the life of the battery.
What I'm experiencing is something different.
Old 04-22-2014, 03:34 PM
Keyser Soze's Avatar
Keyser Soze Keyser Soze is offline
just like that, he's gone
Mein Auto: 2013 535
sure as heck sounds like the Final Stage Resistor to me (had that issue on my old E46)
2013 F10 535i M-Sport, Sophisto Grau, 6-speed MT
2011 E90 335i Sport, Jet Black, Sport Auto, Performance Edition
2002 E46 330i Sport, Jet Black, 5-speed MT, lots of upgrades
2001 E46 330Ci Sport, Steel Grey, 5-speed MT....and more
Old 04-22-2014, 04:05 PM
Would the resistor only act screwy when the AC is on? Seems if it was that it would also act weird when the AC is off and I'm just using ambient or heated air in the car.
Also, do the E90's have this or is it in the blower regulator?
Old 04-22-2014, 05:00 PM
Mein Auto: 2013 535
Yeah, the E46 would pulse if AC/Heater/Fan were on......
E90's are definitely running into the prob although seems a bit early on a 2011....
https://www.bimmerfest.com/forums/sh...d.php?t=420688
Old 04-22-2014, 06:09 PM
Mine only happens when I turn the A/C on. Other than that it works fine. Something related to the A/C.
Old 04-22-2014, 08:29 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Might be it.
Too bad we don't have oscillating fans like Lexus! Wouldn't buy another, but the fan was slick....
Old 08-23-2014, 05:00 PM
Update! Think I have a fix. Replaced the battery and everything seems to be working fine. Felt compelled to follow up since i really hate trying to find info on other issues and read through 25000 pages to discover no one mentions what the fix is/was. Anyway, it seems a low battery will cause all kinds of goofy issues in this car...good times!
Old 08-23-2014, 05:47 PM
DSXMachina's Avatar
Bimmerdex 7.4!
Park with your headlamps on high beam and pointed at a wall. Start the engine and let it warm up. Let the engine idle. Run the AC system with the temperature set to the lowest setting, and with your blower fan in different speeds. Listen for a non-requested change in blower speeds.
1. Does the blower speed vary on its own regardless of the speed you select?
2. Do you see ANY change in headlamp brightness when you sense a non-requested change in blower speed?
