Do I need a new convertible top or can it be saved? - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 04-23-2014, 06:37 AM
nh_handyman nh_handyman is offline
Mein Auto: 1995 325i Convertible
'95 325ic - unclear when (or if) the top was ever replaced.
The rear 'window' needs to be replaced - I know that.
The rest of the roof seems in pretty good shape (with an exception of the flap being loose on the pass side covering some of the gear work and the piping in the picture that is attached).
My question is, this piping that is hanging out in the attached picture, can it be sewn back in?
Should I spend the money to get an entire new roof or just the window? I'll be DIYing the installation.
Old 04-23-2014, 09:58 AM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Bad news. You need a new top. The thread in your top seams has rotted and is breaking down. Eventually (possibly even shortly) that rear seam will split open across most of the rear bow and you'll start to see other seams opening up. You can try sewing that open area back closed, but you'll be chasing that all the way across eventually. Ask me how I know.....
That is exactly how my top died.
Since you'll be DIYing this, make certain in addition to the new top canvas that you get a tension strap set, and the kit with the "bat wings" and cords for the "C pillar"area of the top.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 04-23-2014, 10:18 AM
Great - I'm two-for-two today on the questions and answers.
That is exactly the info I wanted to find out.
I'll plan on a complete roof and did see mention of the tension straps in another post.
Brian
Old 04-23-2014, 02:25 PM
71_340's Avatar
71_340 71_340 is offline
Strength in Knowledge
Mein Auto: 2012 128i Convertible
Looks like the top on mine, seperating in the same spot. I am getting a new top, tension straps, and tension cables all in one kit for around $600.00 on ebay.
I am still undecided if I try to replace it myself or pay somebody to do it. I will get me a price quote for the labor and if I can get it done for $1000.00 including the parts I will not touch it.
2012 BMW 128i Convertible, 2015 F-150 King Ranch, 1969 Chevrolet Chevelle SS
"Quiet Professional"
Old 04-24-2014, 06:16 AM
Thanks again - PM'd for link to kit
Old 04-24-2014, 06:23 AM
dc_wright's Avatar
Originally Posted by 71_340 View Post
Looks like the top on mine, separating in the same spot. I am getting a new top, tension straps, and tension cables all in one kit for around $600.00 on ebay.
If you get a top that comes with the bow clips already glued in place, doing the top is tedious, but manageable. Some of the cheaper tops just give you the clips and the glue and you have to figure out proper placement and wait a day or so for the glue to cure which really extends the time for the job. Just be certain to investigate thoroughly what you're actually getting.
Old 04-24-2014, 07:32 AM
71_340's Avatar
dc,
Thanks for the advice about the bow clips! Got love the forum.
Brian,
I sent you the info you requested via email.
Old 04-24-2014, 04:42 PM
71_340's Avatar
dc,
I am looking to get one of those two kits:
http://www.ebay.com/itm/221423970626...84.m1423.l2649
http://cgi.ebay.com/ws/eBayISAPI.dll...m=281317729266
Looking at the pictures in the listings can you tell me if those have the clips you are referring to already glued in?
Also, since you have already installed a top are there any areas where the replacement top has to be glued on to the frame or w/s header or is this strictly a matter of a whole lot of screws and rivets.
Thanks for your advice.
Old 04-24-2014, 06:25 PM
dc_wright's Avatar
dc,
The first top looks like it's got the plastic parts already glued in place so it should work for you. It's screws, bolts, rivets, lacing, and cursing from there......
Old 04-24-2014, 06:44 PM
71_340's Avatar
Thanks, and I found that talking (cursing) to my car sometimes helps......if nothing else I feel better afterwards.
