E36 (1991 - 1999)
Old 04-23-2014, 08:36 AM
evanwray evanwray is offline
Mein Auto: bmw e36 325i
325i wipers run continuously.
As with most problems, it starts with just a hint to cause doubt that it exists and then suddenly one day it goes totally postal.!
My wipers swiped once while I was driving and I figured I must have brushed the stalk with my hand. A week later they swipe once again, and this time I know it wasnt me that did it. Now suddenly they run continuously as soon as I switch on the ignition.
Thinking there could be a short, I disconnected the stalk control connector to eliminate the controls as the problem, but alas they still run.
I removed the wiper motor and its control arms(what a major pita that was!) cleaned out the motor, which was surprisingly very clean and in good condition considering the cars age, and checked the function of the home position switch which was in perfect working order.
The car has the large double coil relay WI-WA LOWII in it, which clearly energises the moment the ignition is switched on. On inspection it looks ok, but one can never really tell with these things.
My question is, can anybody think or know of anything else that I could check or may have missed short of replacing this relay as BMW SA want a large fortune for it and have a non return policy on electronic parts if its not the issue. Regards.
Old 04-23-2014, 11:06 AM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Sounds like your wiper control module has gone bad. Since the E36 has speed variable wipers, there's an electronic module that interfaces to the instrument cluster that actually controls the sweep of the wiper blades.
http://www.ecstuning.com/ES169272/PriceAlert/
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 04-25-2014, 05:15 AM
The control module is the one that im referring to that BMW want a sh*t load of money for.
Maybe I will try a junkyard instead.
Thanks.
Old 04-25-2014, 08:40 AM
dc_wright's Avatar
Thanks.
I think getting one from a salvage yard would be a good move. Just judging from how seldom we see a post for this problem, the module seems to be pretty low failure rate, so your probability of being able to get a functional one through salvage looks really good.
Old 04-25-2014, 08:46 AM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
Holy crap, $70 for that tiny module??
Harry // 1995 Avus Blue M3 - 2003 Titansilber 530i M Sport - 2010 Black Sapphire Metallic 128i M - Sport // BMW CCA #453346 - North Capitol Chapter // 2000 Silver Audi B5 S4
My Previous Work:
My 325is M-Tech Restoration Thread
My 98 M3 and 03 530i Restoration Thread
Old 04-25-2014, 09:33 AM
Kirkush04 Kirkush04 is offline
Mein Auto: BMW 318i 1995
What was the answer to your wiper problem? My 1995 318 the wipers only work on high speed no low or intermittent ??? any ideas
Old 04-25-2014, 09:41 AM
hornhospital's Avatar
D'oh, You Kids!
Most likely yours is module problems, too. My 318 went through several steps of failure: Wouldn't work on intermittent, then wouldn't work on low, then wouldn't run on high unless it started from the parked position. A used replacement wiper module cured all of that.
The best fix for all of it is RainX.
Quotes to live by:
Old 04-25-2014, 09:53 AM
Thanks for the help I will replace the wiper control module, where is it located?
Old 04-25-2014, 10:08 AM
D'oh, You Kids!
Behind the glove box. Google "E36 glove box removal" to see how to get it out (and more important, to get it back in without it ending up sagging). The wiper module is here:
Name:	wiper module location.jpg
Quotes to live by:
Old 04-25-2014, 10:11 AM
D'oh, You Kids!
Here's a better drawing of the module location. It's #7:
Name:	wiper control module.jpg
Quotes to live by:
