E36 (1991 - 1999)
Old 04-23-2014, 10:30 AM
diggerdan diggerdan is offline
Mein Auto: 93 bmw 325i
93 bmw 325i convertible
turns over but does not start, have no spark at plugs replaced cam shaft sensor and crank shaft sensor still no spark at plugs - what should I try next ?
Old 04-23-2014, 10:34 AM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
Have you checked the relays? Do you have fuel?
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2001 330i DD
Old 04-23-2014, 11:02 AM
93 bmw 325i
I have gas but no spark at plugs - what relays would I check
Old 04-23-2014, 11:21 AM
B1MM3R's Avatar
Jesse Moon Bayne
All of them. Check fuses also.
Jesse
2001 330i DD
Old 04-23-2014, 11:26 AM
is there a way to test the relays - thanks Jesse
Old 04-23-2014, 11:36 AM
B1MM3R's Avatar
Jesse Moon Bayne
Here's a good link. It has a section about testing them also. http://www.bcae1.com/relays.htm
Jesse
2001 330i DD
Old 04-23-2014, 11:48 AM
thanks for the link I will check them and let you know what I find. thank you
Old 04-23-2014, 11:50 AM
B1MM3R's Avatar
Jesse Moon Bayne
ANytime and welcome to the fest'!
Jesse
2001 330i DD
Old 04-23-2014, 01:30 PM
Alika808 Alika808 is offline
Mein Auto: X5/330/Range Rover HSE
Just a basic question, what are the status of the ignition coils?
Old 04-23-2014, 03:21 PM
Also when you removed the spark plugs, what it look like? Are they damp with fuel or dry?
