Help, my transmission wont go into gear! - Bimmerfest - BMW Forums
Old 04-23-2014, 03:59 PM
bmwdriver121 bmwdriver121 is offline
Mein Auto: 335
Hi All,
Been lurking for a while and needed to join to get some feedback.
Today on the way home from work, my manual transmission on my 2010 335i started malfunctioning.
From stop, in first, took off, then pushed clutch in, went to second "grind" ??
From that point, the car would not engage gears 2 4 6
It will engage gears 1 3 5 but to disengage, you must move the stick much lower than before, and once you do it more 'pops' out of gear.
Once stopped, I moved the shifter through the gears. It seems to engage 2 4 6 only after moving the shifter waaaay down almost inaccessible area.
When the shifter was in 1 3 5 it had a ton of free play.
The clutch pedal still has good feel, it seems. Never had other issues.
Because of the displacement of the gear engagement relative to the shifter, could this be linkage? Am I screwed?
I tried calling a local shop but they just said bring it in of course.
Any help is appreciated.
Old 04-23-2014, 05:06 PM
Banned
Mein Auto: 2007-335 HTC
Ooo my god. And some one on here said you never have issues with a manual transmission
Old 04-23-2014, 05:08 PM
Banned
How about you crawl under the car and just look at it. Take some pics and post them. We are not genies
Old 04-23-2014, 06:39 PM
Mein Auto: 335
I do not fit under the car, nor do I have a jack or ramps at this time.
You clearly have nothing to add, move along.
Old 04-23-2014, 09:21 PM
BashedBarrique's Avatar
BashedBarrique BashedBarrique is offline
Mein Auto: 2006 325i
Puh-Leeze! Where did ANYONE say that manual transmissions "never have issues"?
Old 04-23-2014, 09:29 PM
Originally Posted by bmwdriver121 View Post
Hi All,
The fact that gears 1,3, & 5 engage makes it sounds like a shifter or shifter linkage issue.
Old 04-26-2014, 07:28 AM
Mein Auto: 335
I got under the car, and pulled the covers off to take a look. I could barely see the bottom of the shifter, let alone the linkage. I also pulled the shifter boot off to look from the top side.
At this point it must be the connection at the transmission or something inside..
I am having it looked at Monday, hoping it is just a linkage deal. Still disappointed that this happened on a car with only 60k.
Old 04-26-2014, 07:56 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Quite true - OP's issue clearly driver error.
Old 04-26-2014, 08:00 AM
Whoa! Back up the truck - "only" 60k??
Sir, you drive a BMW. BMW. 60k is a time for reflection, appreciation, and major maintenance. Walnut shells?
Old 04-26-2014, 08:29 AM
f1snob f1snob is offline
Mein Auto: 2009 335i Xdrive Coupe
LOL, you're too funny Bashed! Look at post 16 in the following thread.
http://www.bimmerfest.com/forums/sho...d.php?t=765874
I will say it does not sound like the transmission but more likely, as others have said, some sort of linkage issue.
2009 335i xDrive Coupe Space Gray
Premium, cold weather and sport packages
Steptronic, JB4, DCI
JB4 DCI
Old 04-26-2014, 08:52 AM
jsmag8 jsmag8 is offline
Jared
Mein Auto: '09 328i xDrive
I second that. Stop being an ass to the guy. He just wants help. Best of luck buddy, I have nothing to add here unfortunately
Old 04-27-2014, 01:37 PM
mujjuman mujjuman is offline
tappa tappa toit
Mein Auto: hoopty
To me it sounds like a shift linkage issue or trans mount issue
Sent from BimmerApp
mujjuman
Old 04-27-2014, 01:51 PM
I looked at that post and here is what I said,
"I have never had a manual transmission that worked perfectly one day and then wouldn't even move the next day. I have seen many automatics suddenly fail with no warning."
Hardly the same thing as saying " And some one on here said you never have issues with a manual transmission."
Still hate automatics.
Old 04-27-2014, 02:33 PM
Been lurking for a while and needed to join to get some Feedback. Today on the way home from work, my manual transmission on my 2010 335i started malfunctioning.
Dude it's been 4 days. What's the haps?
Oh, and you do have a hydraulic clutch, don't you? Yup, sayin'
Old 05-15-2014, 10:42 PM
Mein Auto: 335
Sorry for the delay,
I towed it personally to a shop and they called back the first day.
Apparently, a couple clips that hold a pin in place in the shift linkage were not in place. The shop that found the issue claim that those clips should not fall off, possibly the last shop sabotaged me!
The clips were lying on the transmission still, after they figured out the problem and re-installed the clips, the car drove perfectly fine.
This re-instills my confidence in the car, I was worried at first, but by no means do I have the view like other people "its a bmw, it will break at 60k miles blah blah"
Old 05-16-2014, 11:26 AM
sptt144's Avatar
sptt144 sptt144 is offline
That was me Quite a few posts popping up lately but I'm sure in the very small percentile range.
Old 05-16-2014, 01:00 PM
Thanks for reporting back.
Glad to hear it was nothing serious.
Old 05-16-2014, 01:03 PM
I thought he was mocking something I had said. I still stand by the statement that manual transmissions have less problems, and when they do occur they are usually of a less serious and costly nature than an automatic transmission (as demonstrated in this case.)
Old 05-16-2014, 07:29 PM
Miller335 Miller335 is offline
Mein Auto: 2007 E92
You see why so many of us try our hardest to never take our cars to a shop.
Old 05-16-2014, 07:34 PM
Banned
as they say, do a search and see the post on OMG my Manual never has issues like the AT have
Old 05-16-2014, 07:41 PM
Banned
My bad I should have said, get to the linkage, either under the car or under the console
which ever, I meant check the linkage to the selectors and by your reply maybe you would have noticed those missing pins, anyway to ALL get a Bentley Manual if you want to know How to fix your car, IF you are just going to take it to a shop to have it repaired , why the heck are you asking us what is wrong with it???????
Old 05-16-2014, 07:51 PM
Watchme Watchme is offline
Mein Auto: 2011 328i E90
if you're grinding - sounds like the clutch is toast (as in it is not disengaging). Pressure plate? Hydraulics?
Old 05-16-2014, 07:57 PM
Banned
he got it fixed got to read the total thread
Old 05-16-2014, 09:39 PM
Well, you should do a pre-emptive valve blast at your mileage. At least look at them, but be prepared to shell out some bucks.
Old 05-17-2014, 04:21 PM
ah! well then.
