E36 (1991 - 1999)
Old 04-23-2014, 09:05 PM
Shmamuel Shmamuel is offline
Mein Auto: e36 325i
Oh CRAP. Hit the rev limiter. Something came out from underneath my car
Ok so occasionally I like to take my really old bmw 3251 e36 out for some fun. I go onto an abandoned road and do peel outs, drift, etc. well today I went our and I tried to get close to the rev limiter without going over. I was stationary, and I floored it and I hit 7000 rpms. I then heard a crack from under my car and something fell onto the ground. I have no idea what it is or what to do (( I know it was stupid and juvenile but I need to know what happened. I have a picture of what came from under my car. It is in many pieces
Old 04-23-2014, 09:09 PM
goosefoot33's Avatar
goosefoot33 goosefoot33 is offline
Manualaholic
Mein Auto: 01 330Ci/02 525iT
That would be one, or two, or three, or all of your fan blades. Replace ASAP. A word to the wise as well- do not rev past 5k without actually moving/have a load on the engine. Check your radiator and underside of your hood- there is a good chance you damaged something when they came flying off.
Sent from my ADR6410LVW using BimmerApp mobile app
BMWCCA Member# 451235
(Summer) 2001 330Ci - ZSP
(Winter) 1994 530i "Greenie" - PARTING OUT! (PM for details)
(Grocery Getter) 2002 525iT
Old 04-23-2014, 09:13 PM
Hellawut??
Mein Auto: who knows?
Yes to this guy above 100% happened twice to me in two years.
-Franklyn
Old 04-23-2014, 09:26 PM
Mein Auto: e36 325i
Actually it's not I just checked my fan and it's totally fine. The blades of the fan are curved and circular these pieces are straight and have a little curve. The fan is in the very front part right behind the grille and that wasn't it
Old 04-23-2014, 09:29 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
It's definitely the fan, but there is nothing wrong with revving an engine when it isn't under load. This occurrence is the result either old engine mounts or an old fan, or both. My money is on the engine mounts being so worn out that they're allowing the engine to move excessively, thus allowing the fan to make contact with the shroud.
Hopefully the OP didn't overheat his engine afterward...
1998 BMW 328is
1966 Pontiac GTO
Old 04-23-2014, 09:37 PM
Mein Auto: e36 325i
Wait are you sure it's the fan??? How far can I drive my car without it overheating?? And can I install a new one myself?
Old 04-23-2014, 09:40 PM
southpark11235's Avatar
southpark11235 southpark11235 is online now
bimmerfest Supporting Member
Mein Auto: 1999 BMW 323is
You are looking at the secondary eclectic fan, not the primary fan. Open your hood and look between the radiator and engine, and you will see the broken fan.
Change the fan is easy with the right tools. http://www.ebay.com/itm/BMW-GM-Water..._Tools&vxp=mtr
Alex//1999 323is - power e46 M3 seats, style 43 rims, 328 exhaust, Z3 rack, Bilstein PSS coilovers
“We got about ten minutes before this entire county is up in flames. If you want to live, you’d better step on the gas! Oh wait is this a Tesla? Sh!t! Well, step on the prissy pedal, we're going to die!” – Cartman
Old 04-23-2014, 09:53 PM
ZeGerman's Avatar
Warm Leatherette
You can install as many fans as you want, but you're going to keep breaking them until you replace the engine mounts...
1998 BMW 328is
1966 Pontiac GTO
Old 04-23-2014, 10:11 PM
Leusent Leusent is offline
Mein Auto: 328is
Aye, looks like primary fan blades.
Winter: 1997 DOHC I-6 2.8L 5Spd BMW 328is (2-Door)
Summer: 1992 DOHC I-4 2.0L 5Spd Toyota MR-2 Turbo (2-Seat)
Summer: 1983/1984/2007 Honda CB550SC/VF500F/CBR600RR (2-Wheel)
Old 04-24-2014, 07:11 AM
JKRIT JKRIT is offline
Mein Auto: '03 525i
To answer the second question, you can drive it as long as the exploding fan didn't damage the radiator or cut one of the radiator hoses so that you start to leak coolant. That's why goosefoot33 suggested that you look for secondary damage under the hood. Of course, there's not much left of the fan, so idling time in traffic is going to be quite limited: watch the temperature gauge like a hawk and shut it off BEFORE the red overheat light comes on.
'03 525i Sapphire Blu/Grey, SP, Nav
'03 530i Sterling Gray/Blk, SP
'02 525it Titanium Silver/Grey, SP
'02 325it Orient Blu/Grey, SP, Nav
Old 04-24-2014, 07:15 AM
Mein Auto: 328is
JKRIT is right. Lots of people delete that fan, so you're probably OK without it for a short time.
I just want to reiterate this point: overheating your engine will be super bad. Like $2000 bad. So *make sure* nothing else was damaged when the fan detonated.
Old 04-24-2014, 07:17 AM
dc_wright's Avatar
dc_wright dc_wright is offline
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
In addition to risk of overheat while the car isn't moving, there's some risk to your water pump bearings with the fan being extremely out of balance. If you can feel vibration I'd limit the mileage you drive it. With just two blades missing on mine the increased vibration was quite noticeable.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 04-24-2014, 08:18 AM
ZeGerman's Avatar
Warm Leatherette
I would not recommend driving the car without having a puller fan installed or modifying the auxiliary fan to turn on at a lower temp. Also, you need to shut the engine off if the temp needle goes even a little beyond the 12 o'clock position. If you wait until the red light turns on, you may have already caused damage due to the buffer built into the temperature gauge.
1998 BMW 328is
1966 Pontiac GTO
Old 04-24-2014, 11:28 AM
Mein Auto: e36 325i
Thanks for all the help guys I appreciate it. But I'm still not sure how to look for damage myself. Should I take it to a shop and get it checked? And also all of my gauges on my bmw are a socially useless. The rev counter and speedometer are fine but the rest are broken
Mein Auto: e36 325i
*BASICALLY useless
Old 04-24-2014, 11:36 AM
M-Track App M-Track App is offline
Past Sponsor
Mein Auto: 2013 M3 e92
I would definitely take it to a shop and have it checked out
Old 04-24-2014, 01:01 PM
ZeGerman's Avatar
Warm Leatherette
Yes, since you seem largely unfamiliar with what to look for or how to fix it, I would recommend taking it to a shop. Tell them exactly what happened, and that you suspect it may be the result of bad engine mounts.
1998 BMW 328is
1966 Pontiac GTO
Old 04-26-2014, 05:50 PM
Manualaholic
Depending on how the E36 engine bay is set up, it may not be the engine mounts (although it is very likely). My fan blade blew apart one time because the bottom of the fan shroud was snapped in half, and one of the sides of the shroud got sucked into the path of the fan blade. Sounded like a diesel engine for a few seconds while all the blades were breaking off. Sounds like something your local shop will be checking out though, good luck!
325i, bmw, crack, crap, e36, limiter, rev
