E36 (1991 - 1999)
Old 04-24-2014, 09:27 AM
Grayracer Grayracer is offline
Mein Auto: 95 E36 M3
HELP! Headlight problem
So..I bought a car with HID's and angel eyes inside Euro housings. The 4 pin connector was crudely connected with loose fitting female pins that weren't well insulated. While I was trying to figure out why the angel eyes weren't working on one side, I accidentally tugged the harness a little and all of the pins popped off and a couple of the pins touched with the light switch on. There was a very small spark and now I have no headlights whatsoever, high or low. I have checked all the fuses - none blown. The relays are not closing. Anybody have any ideas? Thanks
Old 04-24-2014, 09:42 AM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
Welcome to the fest!
How did you check the fuses? Because I'll guarantee that you've got at least one that's blown. You have to use a continuity checker (VOM/DMM). Visual inspection of the fuses won't always show which one is bad.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 04-24-2014, 10:43 AM
Checked all fuses for continuity. Swapped in known good relays and headlight switch. Checked continuity from plugs to chassis ground. Still nada.
Old 04-24-2014, 12:43 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
You likely blew the ballast for the HID bulbs. They're pretty sensitive to start with and they certainly won't tolerate a short on their output.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
