Old 04-25-2014, 12:04 PM
Watchme Watchme is offline
Mein Auto: 2011 328i E90
2011 328Xi AT - Test Drive (Take 2 - E92)
So back from another test drive, this time black E92. A few questions/concerns:
1. The VIN check says it has a Hi-Fi stereo. The dash says "BMW Professional", ONLY right tweeter has "Harman Kardon" written on it. Is this consistent, something off here maybe?
2. Only right side mirror dips when bakcing up, is this normal?
Cheers! Thank you again. The car seems to drive well otherwise!
Old 04-25-2014, 12:19 PM
Nerdboss Nerdboss is offline
Someone might have just thought they were being funny and put the harman kardon logo on the right tweeter. You can look in the back and see if there are speakers in the rear panels, standard hifi will not have those. As long as you don't have the base stereo you should be fine.
And yes, only the right mirror is suppose to dip when in reverse. It's so you can see the curb and avoid hitting it with your wheels.
2011 328i | Jet Black | Oyster/black Dakota | Navigation | Premium package | Sport Package | Heated seats
Old 04-25-2014, 12:22 PM
wilt wilt is offline
Do you midrange speakers on rear doors? The standard hi-fi on 2011 does not have these.
Do you have equalizing capability (tone control)?...If you have midrange speakers on rear doors and equalizing, the front tweeters should have H-K.
BMWUSA.com about the HK Speakers:
"Harman Kardon surround sound system $875
With vehicle-specific equalizing and powerful 420 Watt amplifier. The 13-speaker system includes four tweeters, four midrange speakers, two bass speakers located under the front seat, one midrange in the center dashboard and 2 midrange speakers in the rear door panels"
Right mirror will dip 'automatic curb monitor' and works when the mirror selector switch is set to the Left, but not when set to the Right.
So I set the switch Left if parallel parking, switch to Right when simply backing.
Old 04-25-2014, 01:02 PM
Quick responses - thanks. There's no rear doos (E92), but I don't see speakers in the back at all...
Here's the ad by the way: cars.com
Looks like Hi-Fi stereo?
My only other concern is the N51 (so SULEV model), should I stay away?
Old 04-25-2014, 01:17 PM
I would avoid SULEV models, they can be nasty to repair out of warranty. This car doesn't have the premium package either so no leather seats. You can find similar cars with premium package, heated seats and the n52 engine for the same amount of money,
Old 04-25-2014, 01:30 PM
Seeing as how I like to work on cars, probably let this one go. As I would probably try to DIY maintenance. The seats are leather I think (w/o premium package):
VIN WBAKF5C51BE587209
Type code KF53
Type 328I XDRIVE US (USA)
E series E92 (MUE)
Series 3
Type COUPE
Steering LL
Doors 2
Engine N51
Displacement 3.00
Power 172
Drive ALLR
Transmission AUT
Colour BLACK SAPPHIRE METALLIC (475)
Upholstery LEDER DAKOTA/SCHWARZ (LCSW)
Prod.date 2010-10-13
Options
Code Description (interface) Description (EPC)
S1CAA SELEKTION COP RELEVANTER FAHRZEUGE Selection of COP-relevant vehicles
S203A ALLRADSYSTEM 4-wheel drive
S205A AUTOMATIC GETRIEBE Automatic transmission
S2TMA STEUERUNG GETRIEBETYP Control, transmission type
S2VBA REIFENDRUCKANZEIGE Tyre pressure display
S403A GLASDACH, ELEKTRISCH Glass roof, electrical
S459A SITZVERSTELLUNG, ELEKTR.MIT MEMORY Seat adjustment, electric, with memory
S4ABA EDELHOLZAUSFUEHRUNG NUSSBAUM WURZEL Fine wood trim burr walnut
S502A SCHEINWERFER-WASCHANLAGE Headlight cleaning system
S534A KLIMAAUTOMATIK Automatic air conditioning
S544A GESCHWINDIGKEITSREGEL. MIT BREMSF. Cruise control with brake function
S563A LICHTPAKET Light package
S570A STAERKERE STROMVERSORGUNG Reinforced power supply
S676A HIFI LAUTSPRECHERSYSTEM HiFi speaker system
S693A SATELLITENTUNER VORBEREITUNG Preparation BMW satellite radio
S697A AREA-CODE 1 Area-Code 1 for DVD
S6FLA USB-AUDIO-SCHNITTSTELLE USB/audio interface
S6VCA STEUERUNG COMBOX Control, Combox
S8S4A DECODIERUNG VARIABLE LICHTVERTEILUN Decoding, variable light distribution
S8SCA LAENDERSPEZ. TELESERVICEFREISCH. Telematics access request,country-spec.
S8SPA COP STEUERUNG Control unit COP
S8TLA TAGFAHRLICHT FRONT UND HECK AKTIV Dummy-SALAPA
S8TNA TAGFAHRLICHT UEBER LICHTMENUE EINST Dummy-SALAPA
S925A VERSANDSCHUTZPAKET Dispatch protection pack
Standard equipment
S2K5A LM RAEDER V-SPEICHE 338 BMW LA wheel, V spoke 338
S521A REGENSENSOR Rain sensor
S522A XENON-LICHT Xenon Light
S524A ADAPTIVES KURVENLICHT Adaptive Headlights
S5AKA LED-LICHTELEMENTE LED light elements
S5DSA KOFFERRAUMNOTENTRIEGELUNG Emergency release, luggage compartment
S645A RADIO-STEUERUNG US BMW US Radio
S663A RADIO BMW PROFESSIONAL Radio BMW Professional
S823A HEISSLAND-AUSFUEHRUNG Hot-climate version
S845A AKUSTISCHE GURTWARNUNG Acoustic fasten seat belt reminder
S850A ZUSAETZL. TANKFUELLUNG EXPORT Additional Export tank filling
S853A SPRACHVERSION ENGLISCH Language version, English
S876A FUNKFREQUENZ 315 MHZ Radio frequency 315 MHz
S992A STEUERUNG KENNZEICHENBEFESTIGUNG Control of number-plate attachment
Old 04-25-2014, 02:08 PM
DIY is much easier on normal n52 models. I would keep looking, you can find a better deal. I would skip X-Drive unless you really need it. Transfer case problems are an issue and not cheap to fix.
Old 04-25-2014, 02:10 PM
Some of the SULEV measures for the N51 include:
Near engine catalyst with additional underbody catalyst
Secondary air system
Optimized combustion chamber geometry in cylinder head
Modified piston crown for lower compression
Plastic valve cover with integrated crankcase vent valve and separator (from N52KP)
Stainless steel fuel lines with threaded connections
Radiator with "Prem-air" coating
Throttle system - EGAS08 carried over from N52KP
Airbox with Activated carbon filter for EVAP control
Purge system pipes are made from "optimized" plastic
SULEV BMW's are equipped with vapor tight fuel tanks, stainless steel fuel lines, and some means to control vapor leakage at the engine.
And while the fuel pump is inside the sealed gas tank, From BMW's SIB 11 75 02:
"the emission relevant components are warranted for 15 years or 150,000 miles." The fuel pump and fuel filter both cannot be replaced without replacing the fuel tank, as they are welded together. So while the fuel pump is not specifically mentioned in the list of "Zero Evaporative Emissions" components, one could see that it would be relatively easy for a dealer to find a reason to replace the fuel tank if the pump were to fail. In fact, we have documented evidence of warranty-covered tank replacement for a failed fuel pump. http://chrisparente.com/2011/07/14/w...w-sulev-owner/
Having owned two BMWs which attained 140k miles, and having suffered the costs of unexpected repairs for each in the last two years of ownership, I don't want to own any BMW out to 150k, too much underhood heat and expensive plastic components to fail and need replacement and underhood plumbing to increase R&R time and expense!
Old 04-25-2014, 05:25 PM
Yeah I knew about transfer cases. I guess I will keep looking.
Not that many around without X-drive, unfortunately.
Wow, that is quite a story you linked! N51 sounds like a pain as a complete package.
Old 04-25-2014, 05:59 PM
As you can see, the 'changes' in the N51 is mainly the use of certain components (often used previously in other BMW engines) to help with emissions controls, passive devices that allow the N51 to have similar power/torque as the N52
The point of my history of two BMWs with 140k miles was that ANY BMW or any other car with that many miles is at a point in its life of needing considerable investment in repairs. The sealed gas tank and the inaccessible fuel pump really only become 'an issue' after the 150k mile point -- when fuel pump failure is more costly to deal with.
