Old 04-25-2014, 02:30 PM
jimmelo jimmelo is offline
Mein Auto: 2011 335d
TCU MULF2 questions Telematics
My head is spinning right now after reading lots of posts on this. I'll explain my problem first. Water got into my trunk and it likely fried one those 2 things, maybe both. I became aware when I got the "SOS system malfunction" yellow warning on my dash and nav system. I am now into my CPO warranty and that does not cover the nav/radio/bluetooth.
I can not make calls through bluetooth and my USB ports no longer have power or connectivity either. I have a 2011 335d (E90, build date of March 26, 2010) with Nav, bluetooth. I do not have BMW apps functionality.
What I am trying to figure out is what does the MULF2 control and what does the TCU control? Basically which one do I need to replace?
Here's what the little metal boxes I took out of my trunk say:
BMW MULF2-High Basis SVS
84109229740 - 01 (This is the BMW part #)
EC:965 HW: 13 00 00
AB731098 100991-10 21.03.2010 SW:08.11.00
BMW TCU1.5 MOST GSM US
SW:0D.01.03 HW:19.00.01
84109231090 - 01
Not sure if any of that is relevant. From what I've read I can buy a used ones and replace them. There might be some coding I need to do. Are there newer versions with newer software that might add additional functionality, aka maybe BMW apps? so I can play pandora or itunes via bluetooth? Or how about just not needing to use that Y cable in the center console and just being able to use a USB cable?
Is it worth considering buying something like the MOBridge or Dension Gateway instead?
I've also heard that if I program the SOS warning light away the bluetooth might come back, but I have a sneaky suspicion the water killed the whole device.
Any other advice, info, etc you are willing to share on this I'd be extremely grateful for.
Thanks,
Jim
Old 04-26-2014, 06:49 AM
Mein Auto: '06 AW 330xi
TCU is Bluetooth and BMW assist.
Mulf is a multimedia unit that control Bluetooth and USB input. Maybe something things but I don't think you can have both. Just one or the other. To be honest, not sure on this one
Old 09-02-2014, 12:01 PM
AntonP23 AntonP23 is offline
Mein Auto: 2011 328i Xdrive
Same Issue
I am facing the identical issue with a 328i i just bought (e90)
Upon turning the vehicle on the computer is malfunctioning
so I have no sense of what may have gone wrong. The vehicle was in a hail
storm and the trunk was flooded with water. The TCU and MULF seem to
be irreparable. What did you end up doing or replacing to make the car work
functionally again?
Old 09-02-2014, 12:14 PM
Depending on your year you may be better off getting an upgrade to a combox. It worked really well for me. Check out http://www.bimmerfest.com/forums/sho...784&highlight=
for more info.
Good luck.
Jim
Old 09-02-2014, 12:32 PM
functionally again?
Replace the module and code it.
If you have a TCU and bluetooth is still working but you have an SOS error, you can have BMW Assist coded out of your car. Bluetooth still works but obviously, BMW Assist will not longer work and the SOS error will be gone.
Old 02-04-2015, 08:00 AM
PIXLFIX PIXLFIX is online now
Mein Auto: E70
Any idea how to do it? What FA to remove or what parameters to code? I have US spec with FA #639. I did read, that if I code it out I'll loose the bluetooth.
Old 02-04-2015, 08:10 AM
Add +TELD to the VO and FA_Write to FRM and CAS.
Default (using a profile with manipulation off) FRM, CAS, CAPPL or CIC or RAD2, and I think kombi also needs to be reset.
Old 02-04-2015, 11:31 AM
Mein Auto: E70
Thank you! Will give it a try.
Old 02-04-2015, 09:40 PM
Mein Auto: E70
+TELD did solve the SOS system malfunction error. It doesn't popup anymore.
I still can't get internet to work.
I think the main problem is that I do not see the "globe" icon in the "Telephone -> bluetooth -> paired phones". I see my iphone paired showing the symbols for the phone and audio streaming. But the globe icon (obviously showing the data streaming) is not showing up.
May this be related to my old software version of CIC? After coding "connected drive -> active" I still do not see the connected drive in the menu, but I do see BMW Assist (with internet, concierge, remote unlock etc. functions)?
Shoud "Internet" feature work only with v41 software only or earlier version is OK for internet too?
Old 02-05-2015, 08:27 AM
You need BMW Apps for Internet I believe.
Old 02-06-2015, 09:09 PM
Mein Auto: E70
I just found out that I have at least v45 version of CIC.
So instead of connected drive i have bmw assist in the main menu.
