Old 04-25-2014, 09:48 PM
yea.nee yea.nee is offline
Mein Auto: 335is
Engine start lags and switching gears lag
I have a 2011 bmw 335 is - dual clutch
So I have 2 separate things that are going on that I believe might be issues.
#1 = the engine lags at some point in the day to really fire up - usually the car will start normally , but at some point in the day the car seems to struggle to turn on... Idk if this is normal or not because I'm usually in n out of my car a lot and I'm always starting it and turning it off throughout the day
#2 the car is a beautiful machine and drives great, but sometimes when I go to manually switch gears with the dual clutch system, the car doesn't latch on to the next gear right away. Let's say I redline 1st gear and I click the paddle to switch to gear 2, the car jerks and doesn't catch on smooth sometimes... It happens here and there... I don't know if it has to do with the traction control.
If anyone can relate or have any thoughts please respond
Old 04-26-2014, 06:00 AM
Mein Auto: '06 AW 330xi
For the shifting issues, sounds like your shifting too late. By doing this, you bounce off the rev limiter which causes the delay as the engine cuts power.
You should only really wind out 1st gear. After that, you'll want to shift a bit earlier for the optimal power range.
So 2nd shift at 6800, 3rd, 6700, 4th 6600....
You need to find which at which rpm your power drops off. It will be slightly different for every car.
Old 04-27-2014, 12:40 PM
mujjuman mujjuman is offline
tappa tappa toit
Mein Auto: hoopty
Don't redline 1st gear... That might be causing your delay to shift into and catch 2nd. You can go close to redline but don't bounce off the rev limiter
Sent from BimmerApp
mujjuman
Old 04-27-2014, 01:39 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Don't redline.
If you do, let the car shift for you.
Old 04-27-2014, 01:56 PM
Mein Auto: 335is
Ok and what about the laggy engine startup? The car always turns on, but sometimes it seems to struggle to turn on... Is this a concern of any kind or should I just not worry about it?
Old 04-28-2014, 08:03 AM
Worry.
Your codes?
Old 04-28-2014, 09:08 AM
Mein Auto: 335is
Well that's the thing. There is no codes. The car always fires up nicely in the beginning of the day and more towards the end of the day the startup gets laggy
Old 04-28-2014, 05:14 PM
How do you know?
Old 04-28-2014, 09:27 PM
Mein Auto: 335is
I took it in a month ago and they didn't find anything
Old 04-28-2014, 11:56 PM
To a dealer?
Old 04-29-2014, 07:39 AM
Mein Auto: 335is
Yup
Old 04-29-2014, 05:55 PM
Mein Auto: 335is
When I turn off traction control, my car doesn't cut power or lag on the gear switching. It runs pretty smooth. It might have just been the traction control this whole time.
But my car lags on the ignition startup every so often still.
Old 04-29-2014, 09:22 PM
It's real wrong....what, me codes? I'd do an independent eval w/GT1 or Bavarian Technic. Yes.
Old 05-02-2014, 01:52 PM
Mein Auto: 335is
I'm taking it in on Monday
