Old 04-26-2014, 02:37 PM
Olatunji's Avatar
Olatunji Olatunji is offline
Happy to be nappy!
Mein Auto: 2007 335i Convertible
Smile DIY: Replacing E93 Windshield Reveal Molding
When I choose my 2007 335i convertible, I was shocked by the horrible condition of the molding. The dealer had no plans to fix it, and that was annoying. I read the forums and saw repair prices ranging between $350 and $1,000 and talk about removing the windshield.
All craziness.
I did it myself in about an hour. Most of the time was consumed with cleaning off the old adhesive. Easy job. No real threat of breaking the windshield. Just do it and be happy.
I purchased my molding from getBMWparts.com. The part number for the E93 is 51-31-7-150-646. It cost $27.02. Shipping and tax brought the total cost to $42.92. They double-checked my order to ensure that the part fit my car. I initially ordered 51-31-7-119-711, but that is the number for the E92. Excellent service!
The only other items you need is WD-40 to loosen the old adhesive, rags to wipe away the adhesive as well as clean the paint, and glass cleaner to windshield before attaching the new molding. I used cheap disposable shop rags for the adhesive and microfiber for final cleaning.
Also helpful to have is something stiff with a blunt point to pick out stubborn rubber and adhesive. Try a clean wooden stick. I used a wood shim. Because it's flat, the shim came in handy for pressing down the new molding to help the adhesive set.
There is absolutely no need for a screwdriver or a blade!
If your molding crumbles apart like mine did, then it's good to have some compressed air to blow away the pieces. I used a can of 3M Dust Remover, and my lungs.
Here's a view of the top of the windshield. Embarrassing.
In this shot you can see how bad some of the rubber seals on the roof are starting to look. I have my Gummi Pflege Stift on hand to take care of that later.
To start the project, I let the car sit in the sun for an hour or so to heat up the adhesive. I then used my fingers to pull the old molding out starting on the right side of the car. Start on whichever side you wish. The stiff part of my molding immediately split from the rubber that is glued to the paint and came out easily.
Take your time removing the molding from the corner. But once you get started you can see how it's clamped on and how easy it is to remove.
Here is how it looks when all the rubber and adhesive is cleaned off. Remember that this molding has no impact on the security of the glass. It is decorative and simply fills the gap between the glass and the metal.
I agree with others that it's best to start attaching the new molding in one of the corners. I started on the right corner and then went down the windshield. When you are doing it you'll see how the molding overlaps with another molding at the bottom of the windshield. There is a good amount of overlap there so don't worry.
The trick is to get both of the top corners aligned properly so the curved rubber portion lies flat. There is no adhesive on the corners to keep them flat. It simply relies on proper alignment, so take your time adjusting it.
Press down firmly all along the molding so that it clamps on the glass snugly. You'll be able to judge by sight and feel when it's set just right. No need for banging with a rubber mallet.
Here is the profile of the molding.
When you are satisfied with how it looks, start slowly removing the tape backing and press down on the molding to set it.
Removing backing from the top.
Stand back and enjoy your work! My reward came when a neighbor assumed my car was brand new.
A tip of the hat to others who've posted DIYs, pictures, and encouragement.
http://www.e90post.com/forums/showthread.php?t=834038
http://forums.bimmerforums.com/forum...im-replacement
http://www.e90post.com/forums/showthread.php?t=573281
2007 335i Convertible - Monaco Blue - Saddle Dakota
Old 04-26-2014, 04:37 PM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
Very nice - my 2008 still is in good shape, but it spends a lot of time garaged and not driven in the winter - that Florida sun is rough on it!
Great write up!
Rob
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
Old 04-26-2014, 06:18 PM
Nordic_Kat's Avatar
Nordic_Kat Nordic_Kat is offline
(oO (||||) (||||) Oo)
Mein Auto: 2009 328i E93 MT
Very nice DIY! What a great way to revive a neglected car. So glad to know it finally has a caring owner.
With the new rubber installed, you might try using 303 protectant on it. It is very good for surfaces that get a lot of UV abuse.
Gummi Pflege is great for the squishy soft rubber seals that will absorb products easily, but I've found for the harder less pliable surfaces the 303 Protectant is a great choice.
If your sport doesn't put blood, dirt or grease under your fingernails,
then it's just a game.
Euro Modded|Split Armrest|Rear Foglight Mod|BMW Performance Exhaust|CDV Delete|Shark Fin Antenna Delete|Front Reflector Delete|LUX H8 Angel Eyes|328i|3 Pedals|Das Fahren im Freien| BMWCCA#445793
Old 04-26-2014, 07:03 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Old 04-27-2014, 07:28 AM
Olatunji's Avatar
Happy to be nappy!
Originally Posted by roadkillrob View Post
Great write up!
Thanks! I've been learning a lot here the past couple of months so I wanted to give back a little.
Old 04-27-2014, 07:35 AM
Olatunji's Avatar
Happy to be nappy!
Thanks.
I Gummied the top's seals that afternoon. Next I'll be lubricating the top according to your instructions. Then I'll be fixing the scuffs on the seat bolsters. I want to get everything back into excellent condition before moving on to mods.
Old 12-17-2014, 05:52 PM
Mabidopa Mabidopa is offline
Mein Auto: E93 BMW 328i
Hello guys,
i just ordered the windshield molding for my car and came back to this thread. I have just the problem right now that i cant see any of the pictures.
Does anyone have the same problem?
Thanks a lot
Markus
Old 12-18-2014, 04:08 PM
DallasBimmer's Avatar
DallasBimmer DallasBimmer is offline
BIG D BIMMERS
Mein Auto: '13 535i MSPORT,'10 E93
Originally Posted by Mabidopa View Post
Hello guys,
Thanks a lot
Markus
Yeh, pics are gone, but click this: http://www.e90post.com/forums/showthread.php?t=834038
Old 12-18-2014, 07:19 PM
Olatunji's Avatar
Happy to be nappy!
The pics are back! Sorry everyone!
Old 04-05-2015, 01:42 PM
iii911ooo iii911ooo is offline
Mein Auto: 2008 328i coupe
I just finished this fix on my 08 E92. It went very easy with no problems. It took about an hour with the most time taken to clean up the glue residue. Thanks for posting your process.
Old 09-28-2016, 01:29 PM
Morfm3 Morfm3 is offline
Mein Auto: 2007 328i, 6 spd conv
Another big thank you for this. I got my molding from Bavarian Autosport. It's a bit smaller than yours looks (from the photos), but it worked. Your instructions were flawless. I am lucky and have a whole house vac in the garage with a separate port, so I could suck up the chunks that came off when I removed the old strip. Used WD to get off the crap, then Windex and rubbing alcohol. Honestly, the rubbing alcohol worked best at cleaning stuff after the adhesive was gone. The idea of using wood shims was great. Really helped seat the side channels and get them straight onto the glass, plus after you break off the end a bit, the width is perfect for ensuring an even line for the groove. The only trouble I had was with the top, getting it all seated, but that was just a matter of working with it. Once again, a new shim worked very well in getting the channel over the glass. I put a bit of DAP on the end so the bottom was sealed, since there was only about 1/2 inch overlap.
Once again, great step by step instructions. I saved enough on this that I won't feel so bad when I have to shell out $500 to BMW for a second key and the CC programming!
Muchas Gracias
Old 09-29-2016, 10:33 AM
jat335i jat335i is offline
Mein Auto: 2010 335i
Nice!
Had that done by my trusted mechanic earlier this summer.
Keep my car covered when parked at home/condo (no garage), but still the Florida heat and humidity got to it after 6 1/2 years. Good as new now.
JT
2010 BMW 335i
Monaco Blue Metallic
Premium+Sport Package
Auto/STEPTRONIC
COBB Stage 2, K&N, BMW Performance Exhaust
2005 Mustang GT
Redfire Metallic
5-spd
Ford Racing silver Bullitt wheels
Ford Racing Axle-back GTAs
Diablosport Predator
K&N CAI
http://www.cardomain.com/ride/2046852
1997 Toyota Corolla
http://www.cardomain.com/ride/3237714
1983 Mercedes Benz 380SL Roadster
convertible, e93, molding, windshield molding
