Old 04-27-2014, 10:03 PM
sannouni sannouni is offline
Mein Auto: 2005 330XI, 6Spd, M-Pack
335D loss of power after changing glow plugs
Hi everyone,
I was working on my friends car over the weekend (replacing the Glow plugs on his 2009 335D Automatic), everything went smooth, torqued all the intake manifold bolts and nuts to spec (with new gasket set), changed the glow plugs and their controller (which is also in the vicinity)
after the work was complete, started the engine, it idled smooth. while test driving the car, we noticed that there was a clear loss of acceleration (it's as if the engine is bogging down, or is choking) until RPM reaches around 2500, then the power comes at a big surge (as if nothing is wrong).
we reopened everything to make sure that the work was done correctly, and it was... we put the car back together. the problem is continuing...
the engine codes are
P0299: Turbo Under-boost Condition
P2457: Exhaust Gas Recirculation (EGR) Cooling System Performance
any help and or ideas would be greatly appreciated.... thanks
Old 04-28-2014, 01:57 AM
ctuna ctuna is offline
Mein Auto: 325xi wagon
You might do a search at the following link
http://www.e90post.com/forums/forumdisplay.php?f=377
Don't see much diesel discussion here accept for how great the
mpg's are.
Old 04-28-2014, 08:20 AM
David1's Avatar
David1 David1 is offline
Mein Auto: 07 X3 and 335i
Why in the world would you change glow plugs. They should last the life of the car.
2017 M2 - Alpine White - Black/Blue Dakota | DCT | Executive Package
2009 335i Coupe - LBM - Black Dakota/Glacier aluminum - 6spd | Nav | M-Sport | Premium | Logic7 | Heated Seats | CA |BMW Performance Suspension/M3 control arms| Sold
2009 X5 3.0 - Sold
07 X3 - Sold
07 335 coupe - sold
Old 04-28-2014, 08:23 AM
Nadir Point Nadir Point is offline
Oil Burner
Mein Auto: 335D
Most likely something was disturbed or left disconnected during reassembly.
Old 04-28-2014, 08:27 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
That'sa big-a matzo ball! Do anything with it?
Old 04-28-2014, 10:28 AM
replaced the Glow plugs because he got the code for Glow plug #6 (and we changed the controller because it was close by)
Old 04-28-2014, 05:36 PM
Mein Auto: '06 AW 330xi
Sounds like you left a charge pipe loose or knocked it loose
No idea what the egr code is about
Old 04-30-2014, 03:26 PM
robster10 robster10 is offline
Mein Auto: 2009 BMW 335d
Then you should have ONLY replaced one (#6). Glow plugs (unlike spark lugs) are used in initial startup then high compression, injection of diesel takes over. Sparkplugs (gassers) are used to start and keep it running 1 of the 4 cycles. You must have shaken something loose. Look over conectors, boost hoses etc.
Old 09-16-2014, 06:44 AM
9mmkungfu 9mmkungfu is offline
Mein Auto: BMW 335d
I'm having a similar issue with a 335d. What was the resolution?
Old 09-16-2014, 06:58 AM
We suspected that there was a vacuum leak somewhere... so got a few feet of vacuum hose, while replacing the lines, we discovered that one of the inlets to the vacuum actuators was broken off... Item #1 in the following link (http://www.realoem.com/bmw/showparts...85&hg=11&fg=45) ... we replaced the actuator, and the problem disappeared... and to be honest, it would have probably been possible to glue the nipple back on to the actuator, (the actuator was functioning with no problems)....
Old 09-16-2014, 07:07 AM
Mein Auto: BMW 335d
Thumbs up
Well I guess now you have a spare part Thank you for the reply. I'll check for leaks.
