Old 04-28-2014, 09:21 AM
335IoTwnTrbos's Avatar
335IoTwnTrbos 335IoTwnTrbos is offline
Official 'Fest GIF Guy
Mein Auto: 2008 E92 335i
Talking 100,000 mile 335i
Been awhile since I posted here, wanted to give all my fellow Bimmerphiles an update.
The ride (Io) and I hit 100,000 miles today. Still going strong, but lots of preventative maintenance planned for the near future.
ID:	436304   Click image for larger version
ID:	436305   Click image for larger version
ID:	436306   Click image for larger version
ID:	436307   Click image for larger version
ID:	436309   Click image for larger version
ID:	436312   Click image for larger version
ID:	436313   Click image for larger version
ID:	436314   Click image for larger version
"When you can't run, you crawl... and when you can't do that, you find someone to carry you."
|100,000mile Club (E92)2008 335i SGM "Io"- Cobb Tuned |6AT|Premium|Sport|
|AE Performance CBE|AR Design DPs|CF GTR Vented Hood|Cobb AP V2|SP Lowering Perches (F)|M3 FCAs|VRSF 5" FMIC|
|BMS DCI|Niche Targa M129 18x8/18x9.5|BMS Spacers 10mm/15mm|BP Drilled/Slotted Rotors|BP Ceramic Pads|
|Forge DVs|CP-e Upper CP|VRSF Lower CP|BMS Cowl Delete|MR Front Strut Bar|BMS OCC|Custom CA License Plate|
Old 04-28-2014, 10:23 AM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
When I hit 100K I did the walnut blast, shocks and struts, new tires, an 4 wheel alignment, and a new water pump and thermostat and BMW professional radio LCD display. Like yours, my my car is still running great. It was all DIY except for the alignment. It was about $2,200 in parts but totally worth it. I love the car.
Old 04-28-2014, 10:44 AM
About to get a new set of front tires as my rears were just recently replaced. Water pump and Thermostat were done about 25k ago.
Not sure whether or not my struts/shocks need to be replaced yet as they don't show any of the symptoms of being blown. Plus, I'm still not sure in what direction to go if I do replace them.
Old 04-28-2014, 03:16 PM
DallasBimmer's Avatar
DallasBimmer DallasBimmer is offline
BIG D BIMMERS
Mein Auto: '13 535i MSPORT,'10 E93
Congrats on hitting the century mark. I see four holes where your license plate used to be. Did you put more holes in the bumper to move it to the passenger side?
Old 04-28-2014, 05:02 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Congratulations, 3TT!
Your ride is now broken in, mature, and you may be considering mods. All well and good, but you'll want to pay special attention to your ride from here on out....
There is just one word to keep in mind....to hold close: LUBRICATION
Yes. Lubrication is much recommended - the slipperier the better - you need copious lube to quickly move a piston in 'n' out!
Only with flowing lube can a tight fit be enjoyable - and isn't Joy part of BMW's advertising? Indeed it is, and most BMW pilots greatly appreciate a spirited romp!
So let's get going 3TT - and remember, only with good lube will you experience the Ultimate Driving Machine!
Old 04-29-2014, 09:12 AM
The 4 holes used to be 3 holes from whoever tried to mount the OG center plate bracket to the bumper. I added a 4th because the thought of the asymmetry right in the center bothered/ me off. I just had the bumper repainted and the holes filled so she's all smooth now.
Old 04-29-2014, 09:16 AM
What do you suggest CWB?
Obviously suspension
drivetrain
transmission
5-7k mile oil changes
brake flush
coolant flush
Another question, this is my first car to over 100k miles. Do I need to change to a different weight oil? 0W40 vs. 5W30?
