Old 05-01-2014, 06:32 PM
06bmw330 06bmw330 is offline
Mein Auto: 2006 bmw 330i
halo light rings on headlight out
ID:	437012 would it be cheaper to change this light myself or let Carmax do it for $52? Is this light hard to change?
Old 05-01-2014, 06:58 PM
brundavanam brundavanam is offline
Mein Auto: raleigh
you can buy H8 lamp for $15 at autozone or $6 at rock auto. it is very simple to change. there are lot of you tube videos on how to change , they also called angle lights.
Old 05-01-2014, 07:01 PM
Thanks so much!
Old 05-01-2014, 07:41 PM
I'm a female that says I have to take the tire off and everything just to change the light
Old 05-02-2014, 06:26 AM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2014 i3
$52 to change the bulb isn't horrible if you don't have the tools or the time. But this is one of those projects that you can do yourself... So if you can, why not?
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights, blackline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 05-04-2014, 10:26 AM
True
Old 05-04-2014, 10:28 AM
Mein Auto: raleigh
It is under the hood and all you need is flat screwdriver. Local BMW repair shop asked $30.
Old 05-04-2014, 03:05 PM
mikesevel's Avatar
mikesevel mikesevel is offline
Mein Auto: 328i convertible '08
Stealership H8 charge
My halo ring bulb died on my '08 E93. With a BMW CCA discount, I paid $38 at a BMW stealership.
Is it a bettewr bulb than an Auto Zone version at half the price?
Mikey
Old 05-04-2014, 03:39 PM
Mein Auto: raleigh
Does that light white color or regular red color?
Old 05-05-2014, 06:31 AM
ramblinman ramblinman is offline
Mein Auto: 2008 335
I changed my halo bulb in an e92 a couple of weeks ago. It wasn't difficult, but the video advice and online advice about which way to turn the bulb was contradictory. I had some difficulty getting the old bulb out. I used a screwdriver to lever the bulb in the turn and ended up breaking some of the plastic bulb before I got it out. I wouldn't do that again. On the passenger side, the bulb rotates to the right toward the engine to get it out. There isn't a lot of room for my hand, and i had a tough time getting a good grip on the bulb. I disconnected the wire connector from the bulb first and that was probably a mistake. Keeping the connector on would give you a better place to grip the bulb and turn it. Take your time and you will be ok. The main thing is not to break the headlight housing. That would be really expensive to fix.
