E30 (1982 - 1993)
Old 05-02-2014, 06:26 AM
softdrinkviking softdrinkviking is offline
Mein Auto: *
Question Chrome Bumper Swap
How easy would it be to put the 1980's style chrome bumper assembly from an E30 on an early 90's style E30 that came with the color coded bumpers.
Is the mounting a direct swap, or would it require some kind of modification?
ID:	437050   Click image for larger version
Old 05-02-2014, 02:07 PM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 99' 540i M-Sport
You could swap the front bumpers... but why? That would be a downgrade for the car. The rear bumpers won't work because the rear wheel wells are shaped differently on the late e30's versus the early models.
1999 540i M-Sport
Silver/Black
Still fresh and Minty
1985 335i
Black on Black coupe 5spd
R.I.P
1979 Trans Am 10th Anniversary
#16 of 5,683 made
KOI Import Parts-- 513-771-7777
Old 05-05-2014, 07:31 AM
M-technik-3 M-technik-3 is offline
Mein Auto: 88 M3x2 86 330i 4 e36's
Body lines are different and will not line up correct. pre 9/87 is original E30 and post 9/87 is consider facelift models where the rear arches were lowered and the back valance was extended and the taillights were made bigger.
That being said You could make some sort of mounts to hang them but the molding that goes around the edges of the bumper will never mount to a
facelifted car.
EDIT: I forgot about our 1 year only car, 1988 model's had aluminium bumpers and such the plastic was made for this year for the facelifted chassis. So what I said before does not come into play. Finding someone that wants to ditch their metal bumpers for plastic is very common.
Finding an 88 does not seem as common.
Old 05-05-2014, 03:09 PM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
Most people prefer the plastic bumpers, but I prefer the chrome diving boards once they are tucked.
ID:	437677   Click image for larger version
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2001 330i DD
bumpers, chrome, replace
