Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Z Series > E89 Z4 (2009 - current)
Old 05-03-2014, 10:50 PM
neve1064's Avatar
neve1064 neve1064 is offline
Mein Auto: 2011 328i
All 4 tires reading low all of a sudden
Went to dinner, got back in our 2013 Z435is and the tire pressure monitoring system declared all four tires were flat. I'll check the pressures manually in the morning to clarify if this is actually true. This could be an error in the system I suspect. Anyone have this happen to their Z4?
Sent from my SPH-L900 using BimmerApp mobile app
Old 05-04-2014, 06:22 PM
rmorin49's Avatar
rmorin49 rmorin49 is offline
Mein Auto: 2011 335d
I would be suspicious of a prankster letting the air out of your tires.
COL(Ret), US Army
Hagerstown MD
2016 528ixdrive/MSport
2016 Corvette Stingray (Fun Car)
2013 Audi A6 (Ret)
2013 Audi A4 (Ret)
2010 Z4s30i (ED) (Ret)
2011 335d (Ret)
2009 335i vert (Ret)/ED/PCD
2007 335i vert (Ret) ED/PCD
2000 740iL (Ret)
1998 328iC (Ret)
1990 535i (Ret)
1988 635CSi (Ret)
1985 M635 Euro (Ret)
Old 05-05-2014, 10:12 AM
645/333's Avatar
645/333 645/333 is offline
Michael
Mein Auto: BMW 640i SE Convertible
On all four wheels perhaps the last reply, however the system does not identify which wheel is at fault just that there is a problem. A number of things can cause a warning light, but the first thing is to check all the pressures, if you then pump them up to recommended psi, then do a reset, many people check there tyres, pump them up but don't do a re-calibration and then get a warning light.....
If one wheel is much lower than the others then you probably have a slow puncture........
Always said I would go back to a 6 series
Old 05-09-2014, 07:00 AM
neve1064's Avatar
All four we down around 6 or 7 psi. The temperature in Florida has fluctuated recently. Perhaps this caused air to leak. Filled them back up (36 front / 44 rear) and all good now. Didn't reset though because the warning lights disappeared after that.
Old 05-09-2014, 01:22 PM
645/333's Avatar
Michael
you might want to consider anti tamper valve stem caps.................I would think you have been pranked as the most probable cause........not that letting someones tyres down is a decent prank.......
Old 05-13-2014, 12:13 PM
airmarc airmarc is offline
Mein Auto: Z4 sdrive30i
When there is a drop in temp, all 4 of mine throw a tire low error.
HTML code is Off
