Old 05-06-2014, 07:23 AM
BDSBMer BDSBMer is offline
Mein Auto: 2011 328xi 6MT Sedan
Question De-select Radio Memory Buttons?
How do you de-select a radio memory button on a 2011 328xi without idrive? Thanks!
Old 05-06-2014, 07:49 AM
Towelie Towelie is offline
Mein Auto: E90 335xi 6MT
I'm not sure you can "deselect" in the sense of making the button un-assigned / empty, but to change the selection just go to the desired station press and hold the applicable memory button.
Old 05-06-2014, 08:01 AM
I am looking to d-select as several stations where set in error!
Old 05-06-2014, 08:58 AM
ctuna ctuna is offline
Mein Auto: 325xi wagon
You can only overwrite with something else
You can only overwrite with something else or the same thing.
Old 05-06-2014, 09:43 AM
Flatland328's Avatar
Flatland328 Flatland328 is offline
Mein Auto: 2013 535i xDrive MSport
Your girlfriend busted you listening to LITE FM?
Your girlfriend busted you listening to lite FM?
2013 535i XDrive
M Sport Package, Premium Package, Cold Weather Package
Rear View Camera, Comfort Seats, Ash Grain Wood Trim, Parking Distance Control
Navigation System, Premium Audio System
Other: 08 Silverado Crew Cab Z-71, 06 Mustang GT Convertible
Past: 328xi, Silverado, S-10 Blazer, Grand Prix (x2), Camaro, Accord and yes.......Chevrolet Vega!
Old 05-06-2014, 11:26 AM
ktagly2 ktagly2 is offline
Mein Auto: 2014 BMW 328i xDrive
If you hold down the 1 and 8 keys is should delete them all. Otherwise, like others have said, you have to reprogram each one
Old 05-06-2014, 01:53 PM
Lol; no, but she was trying to find a station and set several with dead air sounds!
Will try and let ya know! Thanks!
Old 05-07-2014, 04:41 PM
Didn't seem to work! Thanks!
Old 05-08-2014, 12:33 PM
Mein Auto: '06 AW 330xi
The radio presets are stored in your key fob.
If you have a spare key that has not had the presets, set yet, you will have a blank slate to start with.
Otherwise the HU needs to be reprogrammed. Not coded, reprogrammed.
Old 05-08-2014, 12:39 PM
Mick the Quick Mick the Quick is offline
Mein Auto: 2011 335i xDrive Sedan
You know that there is this wonderful thing called the Owner's Manual? Not trying to be a jerk, just want you to save some time by going to the source . . .
Mick
Old 05-08-2014, 01:47 PM
I've got a valet key as a backup and will try it and let ya know. Thanks!
Old 05-08-2014, 08:40 PM
ptrcd003 ptrcd003 is offline
Mein Auto: 328i LCI
Mick
The owners manual does not tell you how to de-select shortcut buttons, since it is not possible.
Old 05-09-2014, 11:09 AM
The valet key does not store settings like the normal fobs do. They only contain the authentication chip to start the vehicle.
Old 05-09-2014, 11:33 AM
bocabimmer's Avatar
bocabimmer bocabimmer is offline
Found the Search Button
Mein Auto: 2007 E92 328i, 2014 i3
I think that with the time that's been spent on this thread, we could have all gone out and programmed all 20 FM presets to a random station and reprogrammed them again.
2014 i3 BEV
2007 328i (E92) - BMW Performance exhaust, short shift kit, handbrake and steering wheel trim - CDV delete - CREE LED corona rings - LED license plate lights
2006 325i (E90) - SOLD - projector headlights, blackline taillights - satin grilles - shadowline trim - style 338 wheels
2000 ML430 - SOLD - heavily modded, I miss that truck
Old 05-09-2014, 12:26 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
There's always everyone's favorite - disconnecting the battery and waiting for all the car's remembered settings to be lost.
Now, considering how many things can go wrong when you connect / disconnect a battery on one of these cars, I'd live with the wrong stations. Or program new ones. Still.....
Old 05-09-2014, 01:13 PM
I already did!
Old 05-09-2014, 02:22 PM
Pulling the battery does not reset radio presets or seat memory or any user settings on these cars.
These settings are stored in the key fob.
The only thing a power loss does in these cars is reset time and some adaptations.
Old 05-09-2014, 02:36 PM
Zooks527's Avatar
Hey, learn something every day!
Old 05-09-2014, 04:10 PM
wilt wilt is offline
Mein Auto: 2011 328i
The FM radio only tunes within the range of 87.7 - 107.9 MHz. You cannot tune 000.00 ...when you press 'm' the radio only permits '1' or '8' or '9' as the first digit!
So why not manually tune to 87.7 (the default 'no station') and memorize that frequency (or whatever frequency results in no-station)?!
