E30 (1982 - 1993)
Old 05-06-2014, 06:02 PM
Jeckle Jeckle is offline
Mein Auto: 1987 325es
Check Engine/Oil Light
Here's the issue. I was driving my 87 325es up Mount Seymour in BC with a couple of passengers and the Check Engine Light on the gauge cluster starts flashing. I turn to the warning lights above and see that the check oil light is on as well.
Once I reach the top of the mountain, I keep the engine running and open the hood. Engine seems to be working fine and the oil level appears to be between the minimum and maximum points on the dipstick.
I met up with a few other cars on the mountain and we continued to cruise along the Sea-to-Sky until we reached Porteau Cove with the warning light flashing the entire time. We stayed there for a couple of hours before we then drove about back the other way for a photoshoot. Weirdly, during the trip back the Warning light stopped flashing. However, after leaving the photoshoot, the Warning light started flashing again all the way back home.
My question is what might be the potential problem with the car? Obviously climbing that mountain might have taken a toll but I just don't know how. For the entire day I drove it the car drove fine and the engine was acting normally. The oil level was just below 1/2 soo I'm wondering if I maybe need to do an oil change for the summer.
Old 05-06-2014, 06:08 PM
volvic325 volvic325 is offline
Mein Auto: 323i & 325
I would have stopped the car and not started until I was sure all was ok, sometimes the dip stick can fool you. Having said that one day I parked on a hill and started the engine and the light came on, rolled the car in neutral to a level field and it went away. So it is possible your light came on for that same reason. Go get an oil change to be sure.
Old 05-06-2014, 07:51 PM
downhiller's Avatar
livin large
oil pump could be headin south. or the pick up tube is clogged. remember that light is for pressure, so id start by looking at the pressure switch and doing a oil pressure test
Old 05-06-2014, 08:23 PM
beammeupscottie beammeupscottie is offline
Mein Auto: 1989 325iC
My oil pressue light started flashing and stayed on and went off. Turned out to be a broken wire hitting against the engine metal and when a new wire was ran it was all good
Life is like a roll of toilet paper...the closer you get to the end the faster it goes. So drive an E30 everyday
1989 325iC Alpineweiss II manual 5 speed Curent ride
1990 325i Glacier Blue 4 door Auto, 1987 X 2 (Black 325ic convertable & Granite silver 325i coup) Gone but never forgotten
Old 05-06-2014, 09:22 PM
Thanks for the feedback guys! I might take the car out this weekend and see how the car is then.
