Old 05-07-2014, 06:21 PM
nyviper nyviper is offline
Mein Auto: 2011 bmw 328i sedan
HID Upgrade
has anyone here found a way to bypass the bulb out warning on the dashboard when upgrading the high beams to HIDS? The low beams and fog lights work perfectly, but when I put the high beams in my dash seems to think one of the bulbs is out. its on a 2011 328i with factory halogens.
Old 05-08-2014, 12:05 PM
Mein Auto: '06 AW 330xi
You should code the car to run xenons.
Add option code $524 for xenons and code FRM and CAS. Then default them. This will send a full, un-manipulated 12v to the ballasts as well as remove the BOW. You can also just code the BOW out.
But putting HIDs in a halogen reflector is a downgrade....
