Old 05-11-2014, 06:00 PM
Abbyguy Abbyguy is offline
Mein Auto: 2011 323i
What is it?
New to the Bimmer experience so maybe someone can tell me what is the item in the centre of the pic with the black screw like cap. 2011 323i.
Thanks...
Old 05-11-2014, 06:20 PM
TimothyC TimothyC is offline
Mein Auto: 2011 BMW 328i
Oil filter
Old 05-11-2014, 06:29 PM
Originally Posted by TimothyC View Post
Oil filter
Asked and answered. Thank you. Would not have guessed that. My experience has been the oil filter is located in the lower engine area. But as I stated, new to the bmw experience and on a learning curve.
Old 05-11-2014, 06:31 PM
Anytime! That's what were all here for. And hope you enjoy your new ride!
Old 05-11-2014, 07:10 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Easiest oil filter change going. There's a special wrench for the cap, but you can often get it off with hand pressure alone.
Old 05-11-2014, 08:55 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
oil filter cap
undo this and you see the oil filter inside
either with special tool or your hand with steroids
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 05-12-2014, 05:16 AM
birdman15 birdman15 is offline
new to BMW life
Mein Auto: 2008 328xi
http://www.carcarekiosk.com/video/20...and_oil_filter
Old 05-12-2014, 09:04 AM
DSXMachina's Avatar
Bimmerdex 7.4!
When you reinstall the cap there is no need to make it anything other than snug. It seals by virtue of an o-ring which mates with the wall of the canister and its sealing ability has nothing to do with tightness of the cap. You should get a new 0-ring seal and a drain plug gasket in the box. BMW's part number is 11 42 7 566 327 for use with the N54 335i engine.
Old 05-12-2014, 09:11 AM
Mein Auto: '06 AW 330xi
Haha I had the exact opposite experience.
I got used to changing oil filters on top and when I went to change oil on my sister's VW, the filter was on the bottom. Took me a while to figure that out haha. And also you needed to drain the filter housing before removing the filter.
BMW oil filer is much easier
