Old 05-11-2014, 09:13 PM
bimmerbecs bimmerbecs is offline
Mein Auto:
06 325i I need an answer
So I recently purchased a 06 325i I noticed that the oil level indicator light shows it's at the max fill I drove prolly 1,500miles then it shows it's 1 quart low... I topped it off then noticed I drove another 600 miles.. And it became a quart low again. Why is this?
Old 05-12-2014, 07:11 AM
tim330i's Avatar
tim330i tim330i is offline
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
Welcome to Bimmerfest. I've moved your question over to the E90 3 series forum. This is the forum for your chassis code, you'll get more help in here. Sounds like you have an oil leak.
Tim
Old 05-12-2014, 08:39 AM
Mein Auto: '06 AW 330xi
You most likely have a bad oil level/quality sensor.
I just replaced mine.
You need to drain the oil to replace the sensor so you might as well just do a change with filter etc.
Don't keep adding oil though. It's most likely fine but the only way to know for sure is to drain the oil and measure it.
Old 05-12-2014, 09:09 AM
Mein Auto:
Thanks man,
I have another question. I just replaced the spark plugs last night; #6 plug had oil residue, I'm guessing it's the VCG, what are your thoughts?
Old 05-12-2014, 09:13 AM
Could be and that would be my guess.
There is a sleeve in the spark plug opening that acts as somewhat of a seal. It may just be that. It's a metal shim kinda looking piece
Old 05-12-2014, 09:17 AM
Mein Auto:
Do u know what that seal is called by chance?
~becca~
Old 05-12-2014, 09:21 AM
I don't.
And realoem doesn't show a part # either. It's that cylinder by #20
http://www.realoem.com/bmw/showparts...37&hg=11&fg=15
Old 05-12-2014, 09:25 AM
Mein Auto:
Awesome thanks
~becca~
Old 05-12-2014, 09:33 AM
Banned
Mein Auto: 2007-335 HTC
its just called the Valve Cover Gasket Kit
Old 05-12-2014, 10:17 AM
Mein Auto:
Yea I'm pretty sure it's the vcg
~becca~
Old 05-12-2014, 10:28 AM
Mein Auto:
Also, how long do y'all think I gots before replacing it? I work 13hrs mon-fri so I'll have to do it on the weekend
~becca~
Old 05-12-2014, 10:53 AM
Mein Auto:
The other seal is called the spark plug tube seal..
~becca~
Old 05-12-2014, 12:06 PM
ctuna ctuna is online now
Mein Auto: 325xi wagon
Better study the DIY's before doing the VCG
Better study the DIY's before doing the VCG.
There is a lot of stuff to remove and put back .
Bolts are one time use and you need a good torque wrench.
(and extra pair of hands it looks like)
Old 05-12-2014, 12:28 PM
Mein Auto:
Lol... Everyone underestimates a woman with a tool set. Thanks guys.
~becca~
Old 05-12-2014, 01:27 PM
335IoTwnTrbos's Avatar
335IoTwnTrbos 335IoTwnTrbos is offline
Official 'Fest GIF Guy
Mein Auto: 2008 E92 335i
~becca~
Don't think anyone is underestimating. It's a really involved job and can be costly if not done right. Good luck and let us know how it goes.
"When you can't run, you crawl... and when you can't do that, you find someone to carry you."
|100,000mile Club (E92)2008 335i SGM "Io"- Cobb Tuned |6AT|Premium|Sport|
|AE Performance CBE|AR Design DPs|CF GTR Vented Hood|Cobb AP V2|SP Lowering Perches (F)|M3 FCAs|VRSF 5" FMIC|
|BMS DCI|Niche Targa M129 18x8/18x9.5|BMS Spacers 10mm/15mm|BP Drilled/Slotted Rotors|BP Ceramic Pads|
|Forge DVs|CP-e Upper CP|VRSF Lower CP|BMS Cowl Delete|MR Front Strut Bar|BMS OCC|Custom CA License Plate|
Old 05-12-2014, 01:52 PM
Mein Auto:
Yeah I know I used to have a 00 323i had to do the vcg and head sets. It's not an easy job. And I got extra hands. I never work on a car alone. And I was messin around. Thanks for all your help.
~becca~
Old 05-12-2014, 02:38 PM
Good Luck tell us how it goes.
There are some quirks with these cars you should be aware of.
You can get the the entire set of VCG plus screws and the Valvetronic
Motor gasket at Turner Motorsports I believe.
You will need to reinitialize the valvetronic motor if you change
the gasket for that.
The screws are one time use and you need a good torque wrench ,
I would read all the DIY's on this you can.
There are some good diy's in the maintenance section and DIY
section at this link
http://www.e90post.com/forums/forumdisplay.php?f=16
there are also some at ytube
Old 05-12-2014, 07:03 PM
Mein Auto:
Okay so I need another answer, I tried starting the car on my lunch break, I took approximately 7 seconds for the car to start, then it had a high idle and misfire? That's goes along with the oil residue on the spark plug correct??
~becca~
