328xi Vent Mode - Bimmerfest - BMW Forums
Old 05-11-2014, 09:00 PM
pastman pastman is offline
Mein Auto: 2007 328xi
328xi Vent Mode
Hello Members:
I've owned an '07 328xi since Dec '10 - very happy with it (here in the northeast). Question - does this car have an actual vent mode - venting outside air into the car without the compressor or fan? Something always seems to be running. Please advise.
Thanks,
Alan
Old 05-11-2014, 10:20 PM
ctuna ctuna is online now
Mein Auto: 325xi wagon
If you turn the fan all the way down
If you turn the fan all the way down it turns off
the temp controller completely. Turning it back up or diddling
with one of the other dials turns it back on.
How that effects the vent configuration I don't know.
Old 05-12-2014, 06:00 AM
ashewb ashewb is offline
Mein Auto: 328i
i wonder about this too. seems even in mid 60 degree weather i need to turn on the a/c. the air always seems warm with the switch/ slider all the way to the blue.
Old 05-12-2014, 07:45 AM
Hello ctuna:
Thanks for the reply. This has been my experience also. I'd like to know if there is a "vent mode" - a way to bring outside air into the car without using the compressor or fan. Please advise.
Old 05-12-2014, 07:47 AM
fdriller9 fdriller9 is online now
Mein Auto: '06 AW 330xi
Air re-circulation off, should bring fresh air into the cabin.
Reason it's always warm (with AC off) is because the cabin filter sits right above the engine.
Old 05-12-2014, 08:04 AM
Hello fdriller9:
Thanks for the reply. I failed to shut the air-recirculation off, I think that's the trick.
328xi vent mode
