E30 (1982 - 1993)
Old 05-12-2014, 02:35 AM
nickabluh nickabluh is offline
Mein Auto: E30 318i
positive camber:/
whatsup guys, so i lowered my coilovers today and my front left wheel increased negative camber naturally which is normal. but my front right wheels camber is positive:/ i mean its just perfectly straight. anyone have any idea why that is? and if it is bad to drive with the difference in both wheels? thanks i really appreciate the replys
Old 05-12-2014, 04:41 AM
downhiller's Avatar
livin large
could be a number of things, i would get that wheel lifted off the ground with a jack under the control arm and do a major shakedown.
Old 05-12-2014, 11:38 AM
astroboy424's Avatar
astroboy424 astroboy424 is offline
@antwannnnnn
Mein Auto: 1986 325 "eta"
Doesn't camber plates help with that? I have eibach lowering springs and my left is negative and my right is straight as well so my left wears faster
"OH YOU KNOW.. CAUSE THUNDER COMES AFTER LIGHTNING,
KA-CHOW KACHOW KACHOW" -MCQUEEN
|OO=[||][||]=OO|
/____ALPINA____\
Old 05-12-2014, 11:58 AM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
Both should get some negative camber if the car is lowered, might not be identically the same amount but both should be negative even if minimal.
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2001 330i DD
Old 05-12-2014, 04:39 PM
downhiller's Avatar
livin large
astro, sounds like youre trying to drive nascar tracks backwards.
i would get your car aligned.
Old 05-12-2014, 08:04 PM
logantv logantv is offline
Mein Auto: 1990 325is m20/260
Some great nascar tips:
Old 05-12-2014, 09:47 PM
@antwannnnnn
^^ joksters
And I know, I follow Kevin hart jr. And Jeff gordan lol jk. But isn't it a simple fix? Camber plates? When I let of the wheel it goes straight.
|OO=[||][||]=OO|
/____ALPINA____\
Old 05-13-2014, 04:43 AM
downhiller's Avatar
livin large
if the car is dropped no it shouldnt be like that. it should have negative camber. the only time it should be positive is when the car is in the air. so theres something bent, broken, or misaligned
