E46 (1999 - 2006)
Old 05-12-2014, 09:33 AM
BMWAL99 BMWAL99 is offline
Mein Auto: Truck
Motor was jacked up too far, Popped motor mount and rough idle...help.
The motor was jacked up too far (01 325i) and the motor mount popped. Ran fine before but now the car dies at idle. Some light oil leakage exists. Will run when up to speed and transmission shifts fine. Any ideas on what the possible damage could be?
Old 05-12-2014, 10:13 AM
frvega frvega is offline
Mein Auto: BMW 328i E46 1999
Check and see if hoses didn't get pinched or cut between the engine and body where the engine and transmission are bolt together.
The worse scenario is that you bend the crankshaft where the torque converter is. Check where the oil is coming from.
http://www.bimmerfest.com/forums/image.php?type=sigpic&userid=366102&dateline=1399395586
Old 05-12-2014, 10:22 AM
Mein Auto: Truck
Good suggestions. Would one of these hoses cause the rough idle and motor stalling? Maybe it's nothing too serious.
The oil was something like a half-dollar size on the ground.
Old 05-12-2014, 01:51 PM
MalibuMafiaV's Avatar
TheMalibuMafia
Mein Auto: E60 M5 & JB4+ 335i
Yes. If you popped off one of the CVV hoses or something like the cam sensor wire coming off?. You'll definitely have that issue.
"Be yourself for who you are, or be no one at all" - MalibuMafiaV
TheMalibuMafia.com
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i. Single Turbo 6266.
Audi S4 2000 Stage 3 - Dat turbo spool - SOLD
BMW 2000 3-series - Supercharged Because race car SOLD
Maserati 2004 M128 GT - HREs/tint/straight piped SOLD
BMW 2006 M3 - stock - SOLD
Old 05-12-2014, 03:22 PM
Mein Auto: Truck
Any other suggestions on what needs to be looked at?
Thanks for the help.
Old 05-12-2014, 03:27 PM
TheMalibuMafia
How's your o2 sensors?. Did the wiring come off or anything?. That's about the only other thing I can think of that would come off from almost removing the engine.
TheMalibuMafia.com
Old 05-12-2014, 03:31 PM
Mein Auto: Truck
I'll take a look when I get a chance. It was jacked up way too high (don't ask) popped the motor mounts and then dropped. The rough idle immediately started afterwards. The motor mounts are the weakest link correct?
Old 05-12-2014, 04:19 PM
TheMalibuMafia
Well. Your motor mounts probably needed to be replaced anyways lol. Every E46 needs them after about 100k miles. Maybe a bit sooner than that in my opinion. Especially if you drive it hard.
But other than the things I had said above I really can't think of what else would of been effected. Like the intake is completely attached to the motor so if you moved it. It wouldn't of been damaged.
TheMalibuMafia.com
Old 05-12-2014, 08:17 PM
The fuel hose, depends on how much you pulled, there is an aluminum tube that might got bend and restricting fuel flow.
Are you getting any codes?
Old 05-12-2014, 09:00 PM
Mein Auto: Truck
No codes. The red oil lamp comes on and off intermittently.
Old 05-13-2014, 05:04 AM
Mein Auto: Truck
Elevating the motor could pop an O2 sensor? Still doesn't explain the oil that came out. Looked as if it it was running down from driver side center of the motor.
Old 05-13-2014, 01:15 PM
RainyRider RainyRider is offline
Mein Auto: 03 330i, 91 318/s52
If you have a stock air box and did not have it removed from the car when you jacked up the engine, probably stressed out your intake boot. Likewise secondary air hoses. Oil from drivers side of engine is most likely OFHG leak.
Old 05-13-2014, 01:40 PM
Mein Auto: Truck
So basically I'm looking for disconnected hoses, etc.
Old 05-13-2014, 02:33 PM
TheMalibuMafia
That and electrical wires that go to sensors.
TheMalibuMafia.com
Old 05-13-2014, 03:46 PM
If the oil leak wasn't there before, you are actually looking for a crack, the CVV hose the one to the dip stick is another high possibility, but that will give you codes and you don't have any.
Old 05-13-2014, 06:46 PM
Mein Auto: Truck
What is this part? Mechanic said vacuum leak and pushed on this. Idles much better. He said the mounts were ok but the car's weight dropped down off the lifted motor and to me there is vibration there. There is a light knock as well. Click image for larger version
Old 05-13-2014, 06:49 PM
Mein Auto: Truck
Also the orange oil light comes on intermittently. The car sat there for a few days. No signs of oil on concrete or around motor.
Old 05-15-2014, 09:05 PM
Mein Auto: Truck
So the intake hose was loose. That was the main issue. The radiator fine has a wobble now since it hit the shroud. Runs good so far after I fixed the intake. Still hear I bit of a whistle. Maybe a vacuum. No warning lights except brake indicator lights because I have the module removed.
