Old 05-12-2014, 10:11 AM
elilol elilol is offline
Mein Auto: BMW 328XI 2007
Sanded through something :(
So there was a nice big scratch on the hood of my car that I was sure was only through the clear coat. I decided to sand/polish it out. As I was sanding I noticed the paint around the scratch started to change and a nice nickel size circle formed. I do not know what caused it / how to fix it and what exactly happened. I used 3000 grit paper, very soft sand paper. What do I do?
ID:	439101   Click image for larger version
Old 05-12-2014, 10:17 AM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
you need a repaint. you sanded through the clear, through the base layer, and through the primer in the center. very likely the whole hood will need to be repainted, and the fenders blended.
no way to fix that now, sorry to say.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 05-12-2014, 10:23 AM
Hows that possible? I sanded for only about 3 minutes if not less. When I rub my hand through the area and through that part there is no change at all .
Old 05-12-2014, 10:34 AM
that scratch is through the clear and into the base coat. car paint is super thin, we are talking about a few mils of thickness. 3000 grit sand paper on a sanding block in one area will go through the clear, base, and primer very quickly.
if you cant remove a scratch with polishing compound, sandpaper is going to make it worse as its too deep.
were u sanding it wet or dry?
you can see bare metal starting to peek out in the center of that spot. there's no way to salvage that without a respray of the hood.
Old 05-12-2014, 10:37 AM
I was sanding it wet, what if I buy the OEM Factory paint and apply it to that spot then sand it down to match? will that work?
Old 05-12-2014, 10:48 AM
///MyLittlePony's Avatar
///MyLittlePony ///MyLittlePony is offline
Outside looking in
Mein Auto: 2015 Mustang GT
nope, it needs to be matched. You kind of "went to 11" on that one...if it makes you feel better, I did a similar thing to a crease on my wife's Z4 trunk when I scratched it with a belt buckle and tried to "fix" it.
My Little Pony
Old 05-12-2014, 11:06 AM
There's really no way to fix it diy. Needs to be repainted or else the repair will be obvious
Old 05-12-2014, 12:26 PM
Mein Auto: '06 AW 330xi
expresspaint.com
Old 05-12-2014, 01:50 PM
David1's Avatar
David1 David1 is offline
Mein Auto: 07 X3 and 335i
If you could feel the scratch with your fingernail before you started, it was already over and needed a respray. You could have filled the scratch with paint over time and then lightly sanded that.
2017 M2 - Alpine White - Black/Blue Dakota | DCT | Executive Package
2009 335i Coupe - LBM - Black Dakota/Glacier aluminum - 6spd | Nav | M-Sport | Premium | Logic7 | Heated Seats | CA |BMW Performance Suspension/M3 control arms| Sold
2009 X5 3.0 - Sold
07 X3 - Sold
07 335 coupe - sold
Old 05-12-2014, 02:10 PM
Roleez Roleez is offline
E60 to E90 to E92
Mein Auto: 2011 E92 335i M-Sport 6MT
Went through the same situation with a Honda Accord in my 20s. Sanded a hood chip too far after a touch up with OEM paint in a bottle. Repaired surface was smooth to the touch ... but the repainted area was definitely darker than the rest of the hood, much like getting a drop of cooking oil on a white napkin. Bothered the hell out of me for 17 years. Then I got a scratch and rock chip/dent on my E92's hood a year ago. Amazing what a resprayed hood does to eliminate mental stress.
2011 BMW E92 335i 6MT (Space Gray/Coral):
Premium / M-Sport / CA / PDC / Navi / Rear Shade / Rear Fogs / HK Logic7 / InvisiGuard Film / Dinan Exhaust & Pedals
2006 BMW E90 330i 6MT (Sparkling Graphite/Terra): retired
2008 BMW E60 Dinan M5 SMG (Indianapolis Red/Black): retired
2006 BMW E60 Dinan 550i 6MT (Titanium Grey/Auburn): retired
Old 05-13-2014, 05:29 AM
DSXMachina's Avatar
Bimmerdex 7.4!
"Hon, remember that little scratch you could hardly see on the trunk where I fell in trying to get out the case of Fosters? Well...um...you can't see the scratch anymore!"
