E46 (1999 - 2006)
Old 05-14-2014, 06:36 PM
JF330xi JF330xi is offline
Mein Auto: 02 330xi
Suspension refresh, what do I need?
So I am going to be ordering this kit from bavauto.com http://www.bavauto.com/fland.asp?par...FaZm7Aodlk8AYg
and was wondering what other hardware/parts I need to complete the job. I will be buying the front strut tower reinforcement plates and front strut tower bearings. Car has almost 150k on it and the suspension is SHOT.
Old 05-15-2014, 12:51 PM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
I'd get reinforced rear shock mounts too. At that mileage you probably need new sway end-links and swaybar bushings. Also control arms and CABs. and RTABS.
Note the Bili sports and lowering will give a much stiffer ride over stock. You will intimately feel every bump in the road, not just the bigger ones.
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 05-17-2014, 06:17 AM
Mein Auto: 02 330xi
Thanks for the reply. I already replaced sway bar end links and bushings and I also did the lower control arm bushings about 20k miles ago. So I guess ill be ordering the rear shock mounts along with the suspension kit.
As far as ride stiffness, im not necessarily looking for a stock ride, I just don't want my car bouncing or swaying around turns anymore. Its time for my ride to drive like its supposed to haha.
Old 05-18-2014, 12:56 PM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
I'd spring for the really heavy duty RSM's and be done with it.
http://www.rogueengineering.com/mm5/...ategory_Code=S
