E46 (1999 - 2006)
Old 05-15-2014, 12:46 AM
nickr1985 nickr1985 is offline
Mein Auto: E46 Touring, E87
Car battery just caught fire!
Dear all;
I was just trying to disconnect a the battery so I could re-set the car computer (trying to get PDC working and using advice on another thread).
I used the supplied spanner from the car's kit, and started to undo the bolt on the positive side (should I have started on the negative??)
Suddenly sparks were flying and I dropped the spanner...
The spanner literally burned and burned- it was burnt in half and then proceeded to melt through the battery in flames.
I can now see the fluid in the battery through the hole in the top.
Two things
1) WHAT ON EARTH DID I DO WRONG?????
2) Can I seal up the battery with some metal tape or do I need a new one? Electrics are working.
3) Can anyone recommend a good councillor?
Old 05-15-2014, 01:36 AM
3LOU5's Avatar
3LOU5 3LOU5 is offline
Slacker Extraordinaire
Mein Auto: '02 3LOU5i
How in the hell can a spanner catch on fire ??
Was it made in China out of cheap plastic ????
2016 Toyota Sienna SE - hers
2002 BMW 325i - his
1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers
2011 Tao Tao 50 - whoevers bike is in the shop
2007 Reinell 186 FNS - Aly's and Susi's (our two Miniature Schnauzers)
1995 Fleetwood Flair 27R - EVERYBODY'S
Old 05-15-2014, 01:37 AM
Nope- metal spanner from the BMW tool kit.
Had BMW's for 10 years now- never had a spanner break or wear-= yet this morning it burned in half!
Old 05-15-2014, 01:43 AM
Must have been an extremely severe fire- I think electricity was constantly flowing through the spanner.
It was a bit like the poor guy who had a very gruesome end in 'The Green Mile'!
E46 318i Touring - His
E87 116i - Hers
E39 520i Saloon - Missed
E36 318i Saloon - Sold
E36 316i Saloon - RIP
Old 05-15-2014, 03:42 AM
Tommy D Tommy D is offline
Need for Speed
Mein Auto: '05 BMW 330i
You should always remove the negative first. The spanner probably contacted/laid on the negative and positive terminal at the same time arcing and melting it. Time for a new battery and maybe a fuse.
Old 05-15-2014, 05:38 AM
JKRIT JKRIT is offline
Mein Auto: '03 525i
The spanner won't reach that far. Classic case of the spanner touching the positive terminal and ANY part of the body or battery mount; Everything on the body is negative ground. Better to lose only the battery and/or spanner; A friend once got a nasty burn on his wrist, which got into the short circuit undoing a battery terminal this way.
Get a new battery.
'03 525i Sapphire Blu/Grey, SP, Nav
'03 530i Sterling Gray/Blk, SP
'02 525it Titanium Silver/Grey, SP
'02 325it Orient Blu/Grey, SP, Nav
Old 05-15-2014, 06:13 AM
1972ford's Avatar
1972ford 1972ford is offline
Function over fashion
Mein Auto: 325xiT
Get a new battery.
^^ this. If you even nick something metal while also contacting the + terminal, you'll get sparks or worse, hence the logic of removing the - terminal FIRST. Even then, it's worth being extremely careful. I usually put a rag down to protect nearby metal surfaces if possible when I'm messing with the + terminal. You're very lucky you didn't do more damage.
Old 05-15-2014, 06:28 AM
Scott ZHP's Avatar
Scott ZHP Scott ZHP is offline
We want the Lion!
Mein Auto: 03 ZHP, 01 X5, 73 MGB
Welcome to the wrench welding club. I have a pair of open ended wrenches that I use exclusively for changing batteries. I've insulated them in several wraps of electrical tape (one metric, one fractional). The only exposed bit is the jaw.
Good advice above, ALWAYS remove the negative lug from the battery terminal FIRST. At that point, the chassis is no longer a ground relative to the battery.
JUST...LOOK...UNDER...THE...CAR....for Chrissakes....it`s like checking to see if a dog is male or female....
Originally Posted by smolck View Post
A bimmer with forced induction should have a proper manual gearbox. Anything less is like french kissing your sister.
Old 05-15-2014, 10:34 AM
cvx5832 cvx5832 is online now
Mein Auto: 325Ci, 325Cic, C300
You started with the positive first, there's your problem. You made contact with the body or the bracket that holds the battery down.
Old 05-15-2014, 10:42 AM
1972ford's Avatar
Mein Auto: 325xiT
I'm a member of that club too! I was trying to disconnect a boat battery with a Leatherman tool. I was working on the - side first but I slipped and dropped the tool, it landed on the positive terminal and touched some ground point and it sparked, welding itself open before it fell off the battery (luckily).
Old 05-15-2014, 11:04 AM
Caver Dave Caver Dave is offline
Teufel Hunden
Mein Auto: 2004 330xi
And if you think 12VDC@700-800A is bad... bump that up to 24VDC@1200A
Years ago, was doing battery maintenance (clean/grease clamps & posts) on an M923 with a helper, when he accidentally shorted one of those very large/heavy "military screwdrivers" across some terminals... blew the tops off 2 (of the 4) batteries and instantly VAPORIZED his wedding band, watch, & dog-tags into his flesh!
2004 Titanium Silver 330xi Auto @ 188k - *New* Bosch Alt (130k), G.A.S. DISA kit & 1.2bar Billet coolant cap, fuel filter (133k), Valve Cover Gasket (140k), VDO FuelPump (143k), Giubo & CSB (144k), Cooling System Refresh, CCV, OFHG (155k)
2004 Ford F-350 4x4 C&C w/ 9' steel flatbed, 6.0L early stages of de-alphabetizing
1972 Jeep Commando - AMC304 w/ TBI, TH400, Lifted, locked 4.27s, caged, bumpers, winch, 140A alt, OBA & airhorn... slightly modified for occasional offroad use
Old 05-15-2014, 12:02 PM
racin366 racin366 is offline
Mein Auto: 04 325ci
As said above, always remove the negative first. You're gonna need a battery for sure, and maybe some other things as well, but you won't know that until you get the battery.
Old 05-15-2014, 01:21 PM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
Originally Posted by nickr1985 View Post
Dear all;
Two things
1. Answered above.
2. No, get a new one.
3. A guy named Johnny Walker.
I don't know why, but I became strangely excited when I saw this thread title.....
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 05-15-2014, 03:14 PM
new_kid new_kid is offline
Quietly Learning E46
Mein Auto: 2000 BMW 323i
1) You add Plus and Minus
2) Yes, but sheet metal is better
3) Dr. Kavorkian
Old 05-15-2014, 03:45 PM
Mein Auto: 04 325ci
3) Dr. Kavorkian
If you try to reseal a busted battery with sheet metal or anything conductive you won't need Dr Kevorkian.
