3 Series / 4 Series
The 3 Series / 4 Series Forum. If you would like to see all new posts in all the forums, click here. |
Bilstein: Sport vs. Heavy-Duty
I'm going to get new front struts this spring and was wondering which would suit me better? I have a 2000 323Ci (std sport susp). The OE struts are virtually shot, but I liked the ride/firmness when they were new. I've heard that the Bilstein HD are a better match for the OE shocks, whereas the Bilstein sorts are firmer than the OE. Is that true?
Also, what is the life expectancy of a Bilstein strut? |
For most applications, the only difference between Sport and HD is shock length. The valving is identical. You need to match the shock to the length of your springs. HD is same as stock, Sport is for shorter springs.
2001 325i Touring Alpinweiss/Anthracite cloth, Alpina Softline 1988 M6 Royalblau/Silbergrau Nappa |
From what I've heard from several BMW owners (I have no direct experience) if you replace your OEM shocks with Bilstein HDs using the stock springs the ride will be quite a bit harsher, with a corresponding improvement in handling. If you liked your OEM shocks when they were new, maybe you should get new OEM shocks.
I had Bilstein HD's on my Jetta with stock springs & 17's. The ride was more harsh then my 330i Sport Package, but the improvement in handling over the Jetta's OEM dampers was amazing. Also the HD's have a lifetime garantee.
If you care about ride quality, consider a set of double adjustable konis.
Bilsteins and S/A Konis have a lot of compression damping (much less in the S/A Konis, but it can still be uncomfortable) dialled in. The D/A Konis can be set from softer than OEM to VERY STIFF so you can tailor the ride to your mood and passengers.
2006 GMC Sierra 2500HD 4WD Duramax LBZ/Allison 6-speed 2002 BMW M3 Alpinweiß/Black 1999 323i KP/GTS2 Alpinweiß 1990 325is Brilliantrot/Tan 1989 325is S50B30US Alpinweiß/Black 1989 M3 Alpinweiß/Black S50B32 (321hp, ITBs)
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| NJ BMWCCA Round 2 | Elwood | Motorsports, Racing & Track | 75 | 07-06-2004 04:45 AM |
| Do bilstein sports raise the car with oem sport springs?? | ZIGGURAT89 | 3 Series / 4 Series | 4 | 04-01-2004 10:02 AM |
| Koni Sport or Bilstein Sport?? | srcstc | Tire Rack's Tires, Wheels, Brakes & Suspension | 1 | 06-23-2003 05:19 AM |
| Bilstein Sport Shocks. | obLu | 3 Series / 4 Series | 3 | 10-16-2002 03:50 PM |
| Fs: Brand New Bilstein Sport Shocks (still In Box) $500 | charleysung | Classifieds | 0 | 03-08-2002 11:38 AM |
