E46 (1999 - 2006)
Old 05-15-2014, 09:50 PM
gunthercrumpet gunthercrumpet is offline
Mein Auto: bmw 318i e46 1992
e46 passenger window stuck half way
I have a 1992 BMW 318i e46 and the front passenger window has decided to stick half way and will not move - stuck solid and cannot even push it up or down. I am wondering if the left front window switch located in the middle near the automatic gear stick maybe to blame. To test this can I can simply disconnect the right window switch (which works) and see if will operate the left front window. Will this cause a problem? If this doesn't work then I assume it would be the window lift motor which may be the problem. Thanks.
Old 05-15-2014, 10:09 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Right Church, wrong pew....if your car is actually a 1992, it`s an E36, not an E46.
An educated guess would be that your window regulator is shot....a very common problem on BMWs. Look on Youtube for various DIY repair videos.
The road goes ever onward....
(R.I.P. Jever)
Old 05-15-2014, 11:28 PM
Sorry my mistake. Should read 2002 BMW e46 318i
Old 05-16-2014, 03:07 AM
Tommy D Tommy D is offline
Need for Speed
Mein Auto: '05 BMW 330i
Same answer then as Fast Bob, either the motor is shot and or the window regulator needs replacing. A common occurrence . You will need to remove the inner door panel to inspect.
'05 BMW 330i - 127,000 miles
'87 Ford Mustang LX 5.0L Hatchback - 249,000 miles
'98 Ford Taurus SE DOHC - 116,000 miles
'05 Mazda Tribute s AWD - 118,000 miles
