E46 (1999 - 2006)
Old 05-16-2014, 07:27 AM
bimmer_330i bimmer_330i is offline
Mein Auto: 2004 330i
My 330i overheated and started smoking, there is a leak as well...this light came on
Old 05-16-2014, 07:49 AM
meanda meanda is offline
Mein Auto: bmw
i have the same problem, car over heats quickly (no white smoke from mine but a little condensation) white smoke could mean the head gasket. check your oil see if its milky
Old 05-16-2014, 08:55 AM
ahull's Avatar
ahull ahull is offline
Mein Auto: ist schnell! (03 330i SC)
Originally Posted by bimmer_330i View Post
Attachment 439958
You probably blew the expansion tank. see the e46 wiki cooling section.
http://www.bimmerfest.com/forums/sho...05#post8014505
2003 330i TiAg Sport Pkg ~95k miles
DIY MODS: AA Stage I supercharger, Meyle HD FCAs w Powerflex CABs, Bilstein shocks, Meyle HD Rtabs, Angel Eyes, Clear Corners/Markers w/ LEDs, LED tails, ZHP rims, Akebono pads, AUX input
DIY E46 Merit Badges: Sunroof resurrection, CCV, OFHG, VCG w/ VANOS seals, DISA, Cooling Refresh I, steering giubo, window regs, Magnetic Infandibulator (see wiki)
DIY On deck: Rear Diff bushing. UUC SSK, clutch job eventually, Wavetrac LSD
Old 05-16-2014, 08:59 AM
floydarogers's Avatar
Pedant and Curmudgeon
Sadly, I passed an E39 530i yesterday afternoon that was spilling it's coolant all over the lane. Poor woman looking under the hood... bet they hadn't done a cooling system refresh.
You need to replace whatever has broken - likely the expansion tank or radiator, but also all the hoses including the heater hose at the back of the engine. Unless the radiator or tank is new (because it's already failed and been replaced), replace both of them.
Old 05-16-2014, 09:30 AM
FredoinSF FredoinSF is offline
Mein Auto: 4 BMWs, 1 Jeep, 1 Vespa
My 330i overheated and started smoking, there is a leak as well...this light ...
The light means the coolant level is low. The smoke was likely steam from spilling coolant. Hopefully you stopped driving the car immediately. Driving these cars on low coolant will result in a dead engine. The good news is if the engine is unharmed, refreshing the cooling system is not difficult nor terribly expensive. Here is what I would advise:
1. Do not drive the car.
2. Read the cooling system section of the E46 wiki, then read the whole thing to learn more about your car:
http://www.bimmerfest.com/wiki/index.php?title=BMW_E46
3a. Get car towed to a qualified BMW mechanic to have the damage assessed. Hopefully engine is safe. If that's the case, you will likely need a cooling system refresh. If you have followed step 2 you will understand why it is to your advantage to replace more than one part.
3b. If you are handy and you've determined the engine is safe & sound, order the cooling system refresh kit from the link below and spend a weekend day installing it. http://www.oembimmerparts.com/BMW_E4...rts_s/1863.htm
4. Don't be a stranger. Check back and let us know the outcome.
Old 05-16-2014, 09:35 AM
how much approxmately would i be spending, worst case scenario?
Old 05-16-2014, 09:47 AM
yea i couldnt have drove for more than half a mile when i realized it was overheating and smoking, i turned it off and had it towed home
Old 05-16-2014, 11:49 AM
ahull's Avatar
At 175k, you need the whole kit that includes the rad. I want to say $6-700 for the parts. But you may have had stuff replaced not that long ago so use the kit as a guide and then figure out what you do or don't need by checking against the wiki and the threads linked in there.
or, thousands if the HG blew.... be it rebuild, or used or new engine.
Old 05-16-2014, 01:26 PM
radiator and upper and lower hoses are all new, just figured out that it was the coolant reservoir that has a crack in it
Old 05-18-2014, 06:38 AM
happy
Got the coolant reservoir replaced, she's now back on the road and running like a champ.... and it only cost me $150 to get it all done parts included.
Old 05-18-2014, 08:11 AM
Good job! Those coolant tanks are baaaaad.
Old 05-18-2014, 10:28 AM
yeaa theyre made of plastic so they tend to wear over time
