E46 (1999 - 2006)
Old 05-16-2014, 08:02 PM
Zerottie Zerottie is offline
Mein Auto: 2002 E46 M3
New To The Game - Is It Too Late?
The story has been told 1,000,000 times. I want to learn to drift. More importantly I want to compete in formula drift. I know the idea sounds crazy since I am 20 and have only even tried to drift about 3 times. I work a full time job and am saving up for a car. I want to build a e46 because i know that they are powerful and trustworthy. My questions are how easy would it be to learn to drift in one of these cars? What kind of motor would be an ideal drift swap? Any specific suspension setup? And I'm well aware that this is not an easy or cheap task but I'm well prepared to put forth the commitment to it. So... Thoughts? Suggestions?
Old 05-16-2014, 08:06 PM
japanrot325ci japanrot325ci is offline
Mein Auto: '04 325ci
if you want to start drifting i highly suggest you get a e30 shell and build one from there.
e46 are quite a bit heavy and can cost heck load of money to build a decent racecar.
Old 05-16-2014, 08:08 PM
That's true. What would be a good engine to put into one of those because I know that the stock motor will probably not push out what I need
Old 05-16-2014, 08:56 PM
Fast Bob's Avatar
Fast Bob Fast Bob is online now
Keeping it surreal
Don`t waste your time or money on a BMW....go get yourself an older (Fox-body maybe) 5-liter Mustang. It is FAR better suited to the kind of abuse that drifting will inflict upon it.
As far as E46s being "powerful" and "reliable", well..........
The road goes ever onward....
(R.I.P. Jever)
Old 05-16-2014, 11:07 PM
lgr122 lgr122 is offline
Mein Auto: '00 e46 M43, '05 e87 M47
E46 could be fun in drifting also. If find someV12 engine from 7-series and make it work... that monster torque would make fun.
But then you should truly like working in garage more than racing on track, because you will spend most of your time in garage.
Maybe i would go with 3rd Gen. Camaro for drifting. Loads of aftermarket parts are available out there.
Old 05-16-2014, 11:23 PM
cvx5832 cvx5832 is online now
Mein Auto: 325Ci, 325Cic, C300
No.
Old 05-17-2014, 08:30 AM
bmw330ci04's Avatar
bmw330ci04 bmw330ci04 is offline
Mein Auto: 04 330Ci 6 Spd, 07 335Cic
e46's can drift, i know. but, if you are going to do it, NEVER do it on the public roads, empty parking lots or actual events
oh, yeah, and two words: OPEN, DIFF. if you can get something with an LSD, do it
Old 05-17-2014, 09:01 AM
Fast Bob's Avatar
Keeping it surreal
One more time:
A perfect 50/50 weight distribution, lack of LSD, low power-to-weight ratio, engines that cannot be easily modified to produce more power....
These are all attributes of the E46, and all of them work against the type of setup needed for an effective drift car. The E46 is a poor choice for this task....
(R.I.P. Jever)
Old 05-17-2014, 11:48 AM
TacoBuster's Avatar
TacoBuster TacoBuster is offline
Mein Auto: 2003 325Ci Conv
I think a 240sx is a better choice
Old 05-17-2014, 01:09 PM
racin366 racin366 is offline
Mein Auto: 04 325ci
It's never too late to learn, but to get to the level of formula drift drivers is going to take a lot of time, practice, and tires. I'm by no means a pro level drifter, but I've done my share of it. A BMW would be a poor choice, like above I would strongly recommend a pre 05 Mustang or maybe a 240SX. Mustangs are easy to make the power needed, parts are cheap and easy to find, they take the abuse well, and they are predictable when you kick the back out. Its not as easy as it looks, but it is a ton of fun. If you pick the right car to start with you can get rolling for a small investment. On a Mustang all you'd really need are subframe connectors, gears, a halfway decent diff, and a little more power than stock. Swapping out the rear control arms will make it more predictable and stable, and they are dirt cheap these days.
DO NOT TRY TO LEARN ON THE STREET. You need a lot of open space and no chance of going to jail. You will spin out, slide, and break things along the way no matter how good a driver you are; if you try to learn on the street you'll be lucky if you end up in jail, if you're not lucky you'll get yourself or worse, someone else killed. A lot of drag strips have a road course or autocross area as well and offer drifting events for amateurs, this is a great way to get started, there will be others around with experience that can speed up the learning process, help with parts and repairs, etc. Its a lot of fun, but it is not cheap to learn, even if all goes well you're gonna burn through tires like John Force does. Hope this helps.
Old 05-18-2014, 11:07 PM
heztheone heztheone is offline
Mein Auto: ///M
first things first, u can't learn to drift on ur own, u need proper tutoring or some vid u can follow. as for where to practice, u'r on ur own there
second, forget about BMW as ur drifting machine, go with a 350Z or some old V8 muscle car, these cars have very high torque output (which is what u need). 240SX doesn't have that immediate response u want, specially for a new learner
good luck
Give a man a fish and you feed him for a day. Give a man a Chef and he feeds him for a lifetime
