Old 05-16-2014, 08:48 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
IGNITION COIL TROUBLESHOOTIN' - Easy!
If this is how BMW ignition coils are constructed, most failures would be shorted coil due to insulation breakdown.
What say you?
E9x Bosche Ignition Coil:
Old 05-17-2014, 05:57 AM
DSXMachina's Avatar
Bimmerdex 7.4!
Cal, notice that your top photo is of a conventional coil as used with a mechanical distributor, or very early electronic ignition. That is a two wire, dumb coil. The second photo is of a COP coil, coil on plug, like the ones we have. Notice it takes three wires. Find out why it has three wires and you are on your way to finding out where many failures occur. You must teach yourself my son.
Old 05-17-2014, 06:09 AM
2 low voltage connections for current flow through the primary coil...one high voltage to complete the circuit through the spark plug / secondary coil....
Old 05-17-2014, 09:48 AM
Having read codes to verify misfires, the issue is usually coil pack related, sometimes spark plug, and very rarely wires. But, how would you know what to replace? Below are DIY troubleshooting procedures. Note on spark plugs: Do NOT use anti-seize on threads! BMW plugs have surfaces that don't require this and BMW specifically recommends against. Anti-sieze results in plugs over-torqued! Big trouble - plugs broken off in head possible - best to avoid that!
Coil troubleshooting procedure - might look real dangerous until realizing that shielding runs way down from the top:
[/URL]
R&R Nuts and Bolts:
Old 05-17-2014, 10:30 AM
Saintor's Avatar
Saintor Saintor is offline
Abuser of everything
Mein Auto: BMW-less for now
50% of all my troubles were associated to the BOSCH company, whose products didn't last as expected including spark plugs and a 2 coils. I wouldn't be surprised if the 2 oxygen sensors were Bosch too but I am not sure.
Old 05-17-2014, 10:34 AM
DSXMachina's Avatar
Bimmerdex 7.4!
No. The secondary is induced by the collapse of the primary. The third, and still undefined low current wire isn't needed for that. Continue wax on, wax off, wax on, wax off.
Old 05-17-2014, 10:38 AM
True, but one cannot have current flow without completing the circuit....??
This German guy, not even an EE, said it's all relative. Smart guy! Very grounded.
Old 05-17-2014, 12:21 PM
galahad05's Avatar
galahad05 galahad05 is offline
Better with Butter
Mein Auto: 335i sedan 6MT
I thought it was a sense wire.
Don't resent growing old. Many are denied the privilege.
-- Irish Proverb
Old 05-17-2014, 12:41 PM
Easily, but low voltage? Resistor in there?
I'd o'thought the high voltage side would short before low, and be monitored. Thinner wire, many more turns; lotsa push. Maybe both coil grounds are connected.
_______________________
Ah. Confirmation pulse from primary, diode breakdown. Gotcha.
Old 05-17-2014, 03:02 PM
Miller335 Miller335 is offline
Mein Auto: 2007 E92
I agree.
Over rated company.
Old 05-17-2014, 08:57 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
BAV Auto sells some upgraded coils for our cars. Anyone ever invest? Maybe buy a coil a month?
Old 05-17-2014, 09:19 PM
Guessing: Higher voltage for high & low RPM integrity?
Hey, what is the output of BMW coils?
I've read 35kV for N54, but that may not be accurate. Although, might be right for turbo charge, and certainly accounts for reduced plug life vs. N52, which might be 12kV. Anyone running an automotive o-scope? N55 may be exactly the same coil output.
