Luxv4 -Led cover mod - Bimmerfest - BMW Forums
Old 05-17-2014, 01:26 PM
blue boy's Avatar
blue boy blue boy is offline
Mein Auto: 2011 328ix
I removed the round cover for the halo bulb and modified it to leave the control pad out of the lamp module, i used 1/4 drill for the center hole,,,but that was a little small.
i just used a hand saw to split the cover.... the cover will flex enough to allow the 3 wires to settle in the hole. I used auto body putty to cover the crack. I DID NOT CUT THE SEAL.
this should allow all to run cooler and allow changing color if wanted.
ID:	440257   Click image for larger version
surely goodness and mercy will follow us all the days of our lives
2011 328IX
Ford 150
Gen 3 Prius
Goldwing Trike
Mustang with mods
Old 05-18-2014, 06:37 AM
Mein Auto: '06 AW 330xi
I would cover that with heat shrink.
It's mounted in the housing for a reason. Those dip switches are not weather proof...
Old 05-18-2014, 07:33 AM
blue boy's Avatar
i already thought of the cover just didnt take a photo -- but it never rains under my hood and under body cover seems to keep liquid down, ie that area has never been wet.
the idea is to reduce heat in the lamp module.
each to his own.
2011 328IX
Ford 150
Gen 3 Prius
Goldwing Trike
Mustang with mods
