Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 05-24-2014, 03:08 PM
beamer528e beamer528e is offline
Mein Auto: 1984 528e
Right rear brake binding
I just replaced the caliper, flushed system, (but I didn't replace pads or rotor yet since I wanted to see if it was still binding and didn't want to waste a brand new rotor) and it is still scraping as a drive don the road. Would replacing the pads and rotor keep it from sticking or is this something else? I don't think its the master cylinder because it's only the right rear. Any advice would be much appreciated. Thanks.
Old 05-24-2014, 04:50 PM
catso's Avatar
catso catso is offline
catso
My bet is the piston is stuck or sticking because of crud and corrosion. I would rebuild both rears (fairly easy and inexpensive) or get a pair of rebuilt calipers. You might as well replace your rubber brake hoses while you are in there (inner and outer); they are probably very brittle and prone to leaking if they are the originals and also not expensive either. Breaking the connections loose from the hard lines can be challenging on an old car, so be prepared and make sure you use the correct flarenut wrenches. I had to replace all of mine but now my brakes work excellently.
![/I][/FONT]
Old 05-27-2014, 04:21 PM
hey thanks. So what you're telling me is that the new caliper I put on there was a dud? If that's the case don't order from brakeperformance. I just found out they messed up on drilling the lug holes on the rotors they sent me and their customer service is pretty slow in getting back to me too. Ever hear of a1cardone brand? they have remanufactured calipers for 30 bucks. I don't have the time to do it myself. How are they in quality?
Old 05-27-2014, 08:42 PM
catso's Avatar
catso
I have used Cardone stuff on other cars, it should be OK, but you can usually check if the piston moves in and out smoothly by compressing it.
![/I][/FONT]
Old 05-30-2014, 03:07 AM
PETER NEWMAN's Avatar
PETER NEWMAN PETER NEWMAN is offline
Mein Auto: BMW 635 CSi BMW 730i E38
Rear brake binding
Have you removed the rear disc rotor and checked to see if the parking brake shoes are in good order and not seized up, This is a common problem on these brakes because nobody seems to ever check and service them, peter
Old 07-01-2014, 08:01 PM
BMWFatherFigure's Avatar
Old School
+1 on checking the parkbrake parts, adjustment and actuation. Pull off the primary brake caliper and see if the disc turns freely. If it does it's the caliper. If it is stiff and rubbing its the park brake..
Current:
E38 Parts Car
Previous:
HTML code is Off
