Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E63 / E64 M6 (2006 - 2010)
Old 05-26-2014, 01:43 AM
neftyjr neftyjr is offline
Mein Auto: 2007 M6
Engine Malfunction; Reduced power
Received the message above. Took to dealer and they are saving stuck valve and calling for cylinder head replacement at $19k. Picture showed intake valve open on cylinder 4.
Had someone look at car and feeling is that cannot be stuck or bent valve as car is driving fine except for reduced power only have misfiring.
Second opinion suggested spark plug, fuel injector or coil....
Thoughts and feedback would be greatly appreciated.
Old 08-23-2014, 06:41 PM
certifizel3 certifizel3 is offline
Mein Auto: 2005 BMW 745li
update
did you get your problem fixed??
Old 11-27-2014, 01:23 PM
yungstacksz yungstacksz is offline
Mein Auto: 2008 bmw m6
had the same problem with mines took it to the shop and it was the actuator while there i asked them to check everything and i replaced the actuator the smg pump and clutch
Old 12-17-2015, 05:19 PM
Sensay04 Sensay04 is offline
Mein Auto:
Hey did you get you problem resolved? Same issue happened to mine. I drive centre told me engine malfunction and that it shut down cylinder 5 and reduced speed. I was afraid to take it to the BMW dealer so I found a smaller shop that works on German cars at a fraction of the cost. They told me it was a faulty ignition coil and that my plugs looked foul. The ignition coil was $140 and all ten plugs were $120. They only charged me an hour to do all the work. All and all about $380 after taxes to get my car rolling like new again. You don't necessarily need to take it to the big house to get everything looked at.
