Old 06-03-2014, 01:31 PM
DMN DMN is offline
Mein Auto: 2008 BMW328i
door locks will not unlock with remote
2008 328i
History: (not sure if there any relation to the problem)
Replaced driving light bulbs.
I left the lights in the (ON) position Overnight. Car started fine the next morning.
PROBLEM. Next morning:
-Remote or inside main switch will lock all doors but the passenger front door.
-Remote or inside main switch will not unlock any of the doors.
One of the door lock (15 amp) fuses was blown:
- I replaced with a 20 amp
- As soon as I pressed the remote the fuse blew again.
I need help with the diagnosis:
? Can a bad actuator cause the fuse to blow?
? Since the the front passenger door will not lock or unlock, does that mean this could be the problem actuator?
How to diagnose a bad actuator?
Thank you.
Old 06-04-2014, 12:32 PM
Mein Auto: '06 AW 330xi
Yes.
Probably.
Apply 12v manually, that's about it. If it works, you have a short somewhere along the harness. If it doesn't, it's the regulator.
Sounds like your front passenger door lock actuator is bad
