Old 06-04-2014, 04:09 AM
seso67 seso67 is offline
Mein Auto:
Gas
Hey ppl I have a 2007 328 xi coupe and this thing seems to be a gas guzzler, I usually use sunoco 93 gas. Am i using the rite type of gas? does anyone know what's the best type of gas to put in the bimmer?
Old 06-04-2014, 04:16 AM
BDSBMer BDSBMer is offline
Mein Auto: 2011 328xi 6MT Sedan
From what I read, Shell is one of the better gases to use! http://www.toptiergas.com/retailers.html
Old 06-04-2014, 04:28 AM
CALWATERBOY DUE's Avatar
CALWATERBOY DUE CALWATERBOY DUE is offline
Reregistered User
Mein Auto: 09 E93 335i somewhat mod
Ys
Old 06-04-2014, 05:44 AM
Flatland328's Avatar
Flatland328 Flatland328 is online now
Mein Auto: 2013 535i xDrive MSport
What do you mean by gas guzzler? The car is only rated 17 City / 25 Highway which means that if you are in the 15-19 range in town and 23-27 range on the highway, you are probably about where you ought to be. I'm right there with my 2011.
2013 535i XDrive
M Sport Package, Premium Package, Cold Weather Package
Rear View Camera, Comfort Seats, Ash Grain Wood Trim, Parking Distance Control
Navigation System, Premium Audio System
Other: 08 Silverado Crew Cab Z-71, 06 Mustang GT Convertible
Past: 328xi, Silverado, S-10 Blazer, Grand Prix (x2), Camaro, Accord and yes.......Chevrolet Vega!
Old 06-04-2014, 06:16 AM
joechristmas's Avatar
joechristmas joechristmas is offline
Mein Auto: 2013 335xi M-sport
I've had a solid 22 mpg around Northern Virginia for the last year. An incredible 27-29 on the highways as well. And I'm no puddy foot.
FWIW
YMMV
'74 Duster MT on the column
'74 Cutlass S
'73 Malibu Classic "400"
'86 Cutlass Supreme Brougham 180k
'00 Lincoln LS
'00 328i 120k, Superstorm Sandied
'08 535xi
'13 335xi M-sport, 6 MT
Old 06-04-2014, 06:20 AM
Mein Auto:
Oh ok well that does make sense, but I'm double check the mileage cause I don't work that far but thanks for the input ppl
Old 06-04-2014, 07:11 AM
///M-Furby's Avatar
///M-Furby ///M-Furby is online now
IntarWeb Stalker
Mein Auto: 2016 M3 SO ZCP
Check the owners manual, but i think 89 should be good enough.
Also, your car is a 2007...maybe getting a tune-up would help? If it hasn't had one in a while, then getting one should impress you. Everytime I would get a tune-up (once/year on older cars) the ride would seem so much better (quicker/faster, faster startup, etc)
"Tomato" ED 2016 M3 | B50 | ZCP | X3SW | ZDB | ZEC | ZLP | 2MK | 5DP | 6NS |
"Booberry" ED 2013 335xi | Returned
"Boo" CPO 2006 330xi | Sold
My Drive Style
Because I can.
Originally Posted by cwinter View Post
I agree with furby
Originally Posted by guerilla twang View Post
Hahahaha, I like you furb, you like to live dangerously.
Originally Posted by ProfessorCook View Post
I started to google to find a picture to match furby's suggestion to Gia, but it quickly became clear it was an inappropriate search to conduct at work.
Old 06-04-2014, 07:17 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
Short commutes are killers on gas mileage. Even if you're on the highway, the warmup mode for the engine does not promote good gas economy.
Old 06-04-2014, 08:11 AM
bear-avhistory's Avatar
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
Look inside the gas door for recommended fuel, quick guess, could be wrong but 93 seems to high.
Kevin
CURRENT:
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2014 BMW 435M-Sport MPPK/MPE 8ZF
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
470 WHP of BURBBLES
HOME FROM PAINT
Old 06-04-2014, 08:15 AM
Mein Auto: '06 AW 330xi
Small things like tire pressure, worn bushings, missing undercarriage shields, etc can reduce gas mileage
Check those things out.
Driving with windows down even affects gas mileage
Old 06-04-2014, 08:28 AM
Reregistered User
W/O chip I found no more than 19.1 mpg combined.
Then I discovered my right foot was big boned! Weighed heavily on the pedal.
Have to admit that, in spite of my handicap, our Hondas always did much better. Yet none of them could easily zip up to 150 mph, or even approach that.
Why??? Please help!
Old 06-04-2014, 11:11 AM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Monthly 'Fest octane question ... [right]
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 06-04-2014, 11:31 AM
wilt wilt is offline
Mein Auto: 2011 328i
There are two octane numbers: Highly Recommended, and Minimum
For my 2011 328i...
  • The inside gas door and Owner Manual both state Highly Recommended = 91
  • The Owner Manual states Minimum = 87
Using higher than 91 derives no benefit, only drains your wallet faster.
Some gas octane myths pertain to MPG, as well as to engine harm, myths addressed here: http://www.bimmerfest.com/forums/sho...&postcount=156
Old 06-04-2014, 11:32 AM
mike@x-ph.com mike@x-ph.com is offline
Mein Auto: FBO 07 e92 335i
i have definitely noticed the difference in gas quality from different gas stations.
I now only use Chevron or Shell.
That being said i look for performance and engine knocking resistance, in your case it might be different since you would probably be looking to best gas mileage.
Old 06-04-2014, 11:42 AM
Mein Auto:
Thanks for the advice ppl
