Old 06-06-2014, 05:02 AM
updownsidewall's Avatar
updownsidewall updownsidewall is offline
Mein Auto: 2007 328i
Starter Removal, 2007 328i
To those who wan to do it yourself, be prepared for a fun job. First disconnect neg on battery, then remove cabin air cover and cover below that and then engine cover with 4 allen screws.
Do not remove fuel bar, disconnect electrical on fuel bar( two connections) then remove air filter and hose to throttle assembly. disconnect all connections on intake manifold. Remove two nuts on power steering tank and set aside out of the way.
Remove two torx screws on electrical distribution unit connected to intake , be sure to have solid connection to remove screws. Replace with two 6mm bolts. This is the hardest part of the job. Remove hose to throttle and remove throttle, replace gasket on throttle.
Remove intake manifold, replace gaskets, be careful, two hoses on back of intake and one elect connection. These are hard to remove, don't break hose. Remove manifold and starter is easy to remove. Disconnect elect and remove two torx bolts, E-14 socket. Buy a rachet with a swivel head to remove long bolt, also use penetrating oil and hope they free easy. Replace with new bolts
The hardest part for me was the air filter installation, took me an hour. It is a tight fit.
Savings 1000 dollars. Hope this helps as repair manuals never seem to be written by someone who ever did the job. Many mistakes, I just went to with looking each step as I was doing it, of course experience helps. Buy parts on e-bay Total cost of job $ 163 dollars, Starter, bolts, and gaskets.
Last edited by updownsidewall; 06-06-2014 at 05:12 AM. Reason: Left out parts buying
Old 08-31-2014, 01:29 PM
Anderoo_328i Anderoo_328i is offline
Mein Auto: '07 328i
Thanks I am about to attempt this courageous adventure..
Did you use any videos to help you?
I'm more of a visual person.
I slept and dreamt that life was joy. I awoke and saw that life was service. I acted and behold, service was joy.
-2007 328i
Old 08-31-2014, 02:59 PM
Mein Auto: '07 328i
-2007 328i
Old 09-01-2014, 05:06 AM
Smile Sarter removal procedure
I did watch a video, but they did it wrong in removing equipment that was not necessary. You have to be patient as room is tight. Hoses are hard to remove due to heat seizing and when reinstalling coat inside with soap to ease installation. Make sure electrical connections are secured tightly when installing. don't over tighten intake bolts. Engine service light will stay on until you drive it a few miles. BMW is good about hose alignment with key indexing. Lowes has ratchet swivel head to get bolt on back of starter. Leave trunk door open after removing neg terminal on battery. If you forget your key will open it. Good luck and if you need help e-mail me.
Hope this helps
Old 09-01-2014, 07:03 AM
Watch out for oil in intake manifold, depends on how many miles on vehicle. Be prepared
Old 09-01-2014, 09:34 PM
Mein Auto: '07 328i
The left bolt to the starter is
-2007 328i
Old 09-01-2014, 09:35 PM
Mein Auto: '07 328i
Stripped.
And the bolt head is entirely off.
What should I do
-2007 328i
Old 09-02-2014, 05:07 AM
If the head is completely gone and you removed the right one it should come right out when you say left is it the long bolt or short one bolt threads in starter other in engine. Which is it? Make sure no part of bolt head is holding starter on. If so file or grind it free. Did you use penetrating oil on bolts? Sorry you are having this happen.
Old 09-02-2014, 05:18 AM
Watchme Watchme is offline
Mein Auto: 2011 328i E90
Hammer on a smaller socket on it, make a line slit in it (using dremel) - for the screwdriver, vice grips, etc.
Hope it works.
2011 328i X-Drive Sedan N51 AT; Black / Black.
Premium, Value, Hi-Fi stereo, etc.
Old 09-02-2014, 05:30 AM
Banned
Mein Auto: 2007-335 HTC
how about a pic of it, the bolts are AL so grinding should be easy so to speak, maybe try to get a knife blade between the starter and the block and pry it out, could be some corrosion holding it together
Old 09-02-2014, 05:42 AM
Mein Auto: '07 328i
I am the second owner, and by the looks of it I can tell the starter has been changed once before. And when they bolted it back on the used two different bolt the right one was short and threaded all the way up, On The left on the the bolt head is all the way off and I can see the threads. I did use penetrating oil it didn't seem to help. I will try filing the top down some more.
-2007 328i
Old 09-02-2014, 05:43 AM
Mein Auto: '07 328i
Sure thing.
I'll get some pics up as soon as I'm off work.
-2007 328i
Old 09-02-2014, 06:18 AM
The long bolt threads into starter flange the short bolt threads into block. do what was suggested to free flange from block use two new al bolts . don't over tighten. Odd it should break free with pressure from pulling up on starter.
Old 09-02-2014, 12:05 PM
Mein Auto: '07 328i
Here what it looks like
-2007 328i
Old 09-02-2014, 12:47 PM
Banned
if you have the other bolt out the starter should slide forward, you might need to pry it off, you have a new starter correct? check but I am sure the starter housing is not threaded
Old 09-02-2014, 03:24 PM
only the long bolt threads in starter flange. I'm surprised at the corroded area, mine was like new. I believe this engine has seen much water. Maybe a flood. For a 2007 it is strange. need to pry starter off.
Old 09-02-2014, 03:37 PM
Banned
What sucks about this thread is that the starter has to be replaced. AGAIN. With that little miles. Again BMW cheaping out on components
Old 09-02-2014, 03:40 PM
Banned
Dissimilar metals. Galvanic corrosion. Make sure you grease the bolts
You should be able to pry it loose
Old 09-05-2014, 03:43 PM
Mein Auto: '07 328i
ID:	462737i got it off, I used a Reciprocating Saw. And found out what the problem was that some one just put the bolt in backwards.
-2007 328i
Old 09-05-2014, 05:33 PM
Tyrell Tyrell is offline
Mein Auto: 2007 bmw 318i se
Bmw 318i CBS display
Hi, I'm new here, and I just bought a 2007 bmw 318i se, I have been looking online about the car, and I notice my car doesn't have the middle CBS on my dashboard(warning signs)! It only have the bottom and the top part... Is that normal please help... Thanks.
Old 09-05-2014, 10:27 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
Attachment 462737i got it off, I used a Reciprocating Saw. And found out what the problem was that some one just put the bolt in backwards.
Awesome! Can't see the paty where you cut it though in the picture. Congrats! Scared myself a few times with critial stripping of hard to reach bolts as well.
Old 09-06-2014, 01:03 AM
Banned
so basically it was held on by the bottom bolt! wonder what idiot fixed it the last time
Old 09-06-2014, 01:04 AM
Banned
dude you need to start your own thread, this one is about a starter that wouldn't come off
I am surprised the moderators didn't remove this post since it has noting to do with the OP topic
Old 09-06-2014, 05:40 AM
Bolt
Makes no sense in it being backwards. It would not hold flange to block, are you sure about the bolt?
Old 09-06-2014, 08:13 AM
Mein Auto: '07 328i
What happens if I don't replace the gaskets...?
-2007 328i
