Old 06-10-2014, 07:47 AM
infiniteuser infiniteuser is offline
Mein Auto: 2008 335xi
335xi Water Pump - DIY replacement
Does anybody have a link to a DIY for replacing the water pump on an 08 335xi? Or anybody actually done it themselves? Everything I've found is for the non-xDrive model.
I'm at 87,XXX miles so I think it's time to do it before it goes out on me.
Old 06-10-2014, 08:22 AM
brewder brewder is offline
Mein Auto: 2011 328i xDrive
How's this:
http://blog.bavauto.com/14581/bmw-ho...55-6-cylinder/
//Brew...KCCO
('11 E92 328i xDrive - Deep Sea Blue | '07 E92 328xi - Space Gray)
Old 06-10-2014, 08:25 AM
Saw that, but it specifically says not for xi/xDrive models in the first couple seconds of the video. Still useful, I'm sure most of it is similar, but I'd like to find information specific to my car.
Old 06-10-2014, 09:29 AM
fdriller9 fdriller9 is online now
Mein Auto: '06 AW 330xi
The front subframe/diff/axles kind of get in the way.
If you don't drop the subframe, you need a ton of swivel joints and extensions of various lengths.
It's doable without dropping it but you will have MUCH more clearance. I did my pump without dropping the subframe but second time around, I will drop it.
The hardest part was getting leverage to pry the hoses off. Accessing the top pump bolt was also a pain.
Old 06-10-2014, 11:46 AM
Thanks, fdriller. So other than clearance issues because of the extra drivetrain components, is the pump still mounted in pretty much the same place as the non-xDrive model?
Old 06-10-2014, 11:52 AM
Exact same location.
Old 06-10-2014, 11:54 AM
Cool. Thanks for the info.
