Old 06-10-2014, 01:00 PM
john Dew john Dew is offline
Mein Auto: 07 E90/09 Porsche Turbo
Run Flats OR Non Run Flats?
I have a 2006 325i Sports Package with 68,000 miles-
Once again after 15,000 miles I need new tires and since my warranty is done I'm looking at non run flats-
I have only put the Bridgestone Potenza retail $255 each, very happy with performance and not too loud but don't like the cost every couple of years-
Pros Cons Anyone? I've read a lot of posts but no one has said absolutely on Non RF without going into tire pressure and other possible problems-
Thanks in advance-
Old 06-10-2014, 01:05 PM
wkdpanda wkdpanda is offline
Mein Auto: 335i Convertible
Been very happy going from run-flat to non-run-flats. Changed to Continental Extreme Contact DWS, and been very happy with the better ride. They are quiet and my back doesn't complain going over every crack in the road.
Old 06-10-2014, 01:51 PM
Mein Auto: '06 AW 330xi
I switched from Michelin Pilot Super Sports to Bridgestone Pole Position S-04s. I like the S-04s so far. They ride a bit stiffer than the PSS though. Both are non-RFT.
But for about $300 cheaper than the PSS, the S-04s are great. Paid about $800 for 4 with TireRack's road hazard warranty.
Old 06-10-2014, 02:09 PM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 16 435 CV Msport PPK/335d
At Tire Rack you can get 4 good go flats tires and a conti kit, and still save money over buying RFT. As an added bonus Pilot SS or S-04's are much better tires, in every regard. N4S
Old 06-13-2014, 10:00 PM
StoopidFlexin StoopidFlexin is offline
Mein Auto: 2011 328i M-Package
Thanks in advance-
You have to get run flats to not void the warranty? Can someone clarify?
Old 06-13-2014, 10:17 PM
Last Sight's Avatar
Last Sight Last Sight is offline
Mein Auto: BLT335xi, e92 6MT
Tires aren't a warranty item from BMW nor would putting RFTs vs. non-RFTs change that (obviously assuming everything is the same size, etc).
Usually if you are leasing a car, you have to put RFTs back on the car when you turn in the lease. Not sure about BMW but I'm assuming it's the same since MINI requires the same tire that the car came with.
BMWCCA #489063
The BLT335xi - '11 BMW 335xi, M-Sport, Convenience, Premium, H/K sound, iDrive
1974 Corvette - blue, 4spd, fully loaded
Previous Rides:
'13 Cadillac ATS - Fired
'09 BMW 328xi - KIA by Bambi, reincarnated in Michigan
'01 Saab 9-3 2.0T
Old 06-13-2014, 10:23 PM
mntgoblu328icpe mntgoblu328icpe is offline
M235i ///M
Mein Auto: M235i
I actually like the run flats. THey are very durable, and they really add to the sports car feel. Like that ruff ride!
Old 06-14-2014, 07:18 AM
need4speed's Avatar
Man that is a good one! N4S
Old 06-14-2014, 09:26 AM
Wagon3 Wagon3 is offline
Mein Auto: 2006 E91
Just got the Michelin Pilots and will not go
back to run flats. Got my 4 from Costco for
$525 out the door. They are running a $70 rebate
May and June. I just have the base 16 inch rims
though. They also balance every 8 k miles
free.
M235i ///M
Mein Auto: M235i
At least mine are.... I've had the same nail in one of my tires for like two months. Still drives like a champ LOL...
Old 06-14-2014, 09:29 AM
M235i ///M
Mein Auto: M235i
How good are those NON RF Michelin tires though??
Aren't they a cheaper, less superior tire???
I feel like the run flats really can take a beating and keep on going...
Old 06-14-2014, 10:54 AM
galahad05's Avatar
galahad05 galahad05 is offline
Better with Butter
Mein Auto: 335i sedan 6MT
I run the pilot super sports. Great tires--superior traction rain or shine.
Slightly noisier than my last set though (bridgestone stock sport-package runflats, whatever model they were (the W-rated ones)).
Don't resent growing old. Many are denied the privilege.
-- Irish Proverb
Old 06-14-2014, 11:59 AM
CALWATERBOY DUE's Avatar
CALWATERBOY DUE CALWATERBOY DUE is offline
Reregistered User
Mein Auto: 09 E93 335i somewhat mod
You must immediately, and without delay, go HERE
Old 06-14-2014, 03:22 PM
Last Sight's Avatar
They're cheaper because they're non-RFT but no cheaper in terms of quality.
Most people on the forum go with Conti DWS. I'm running Hankook Ventus Noble2's and I prefer them over the RFTs. Also, I pay $620 instead of $1200 for RFT Max Performance Summers that came on it.
BMWCCA #489063
Previous Rides:
'01 Saab 9-3 2.0T
Old 06-14-2014, 05:04 PM
Bemo's Avatar
Bemo Bemo is offline
Mein Auto: 2011 328xi
Here we go again with this topic. Drive both and decide for yourself. Don't listen to anyone else. If cost is the biggest factor, you should look to sell the car as you'll face bigger expenses down the road.
2015 911 Carrera GTS
2011 328xi
2011 535xi GT
BMW CCA
325i sports package 2006, best tires, non run-flats, run flat
