Old 06-10-2014, 02:23 PM
spankey spankey is offline
Mein Auto: 335xi
Will 245/40/17 be ok on a stock 07' 335xi
I need to replace my tires and want to know if 245's will rub at all on a stock setup? Anyone else running 245's on a 335 or 335xi?
Old 06-10-2014, 03:03 PM
Mein Auto: '06 AW 330xi
Why are you changing tire sizes? What do you expect to gain?
Old 06-10-2014, 03:06 PM
Mein Auto: 335xi
More looks than anything. I guess 2 centimeters in width isn't all that great though or even noticeable.
I also notice that my speedometer seems to be 3 miles per hour faster than what it is. Hoping going to a 40 will offset that a bit? Could I be wrong?
Old 06-10-2014, 06:33 PM
Well I'm not sure if it will rub but if I had to guess I would say it's ok, especially on an xdrive. But wait till someone else comments
As to the speed issue...the car is programmed with a speed correction that is 3-5% faster than your actual speed. This can be coded off
Old 06-10-2014, 07:01 PM
Mein Auto: 335xi
Thanks that's good to know on the speedo issue
Hope someone replies on the tires rubbing
Old 06-12-2014, 03:18 PM
Mein Auto: 335xi
I stayed with my stock size. Went with the conti extreme DWS's
Love em' nice and quiet and handle great
