2007 328i Tire Size - Bimmerfest - BMW Forums
Old 06-10-2014, 08:22 PM
rbecker08 rbecker08 is offline
Mein Auto: 328i
2007 328i Tire Size
Hey guys new to the forums and BMW ownership in general. Time to replace tires and I noticed I have 255-40-17 in the front and 255-45-17 in the back. Those numbers mean little to nothing to me but I know that 45s are around .5 inches taller then the 40s. I would prefer that all tires are the same size to allow me to rotate them correctly, is there an issue with using the 45s or the 40s all the way around and if not which is the better choice. Thanks for the advice.
Old 06-11-2014, 06:48 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
Please check your tire sizes again. Perhaps you have 225/45R17 in front and 255/40R17 in the rear? At least that's what BMW intended for '07 328s. In addition, your front wheels are 8.0" width and the rears are 8.5" width, so what did you have in mind for rotation?
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 06-12-2014, 03:35 AM
brewder brewder is offline
Mein Auto: 2011 328i xDrive
Actually, I'm 99% certain that the standard setup for the 2007 328's is 225/45R17.... Base and Sport model for the 328xi at least... I've replaced mine 3 times, and that's been the setup each and every time.
Check your owners manual or hit-up www.tirerack.com for more info.
//Brew...KCCO
('11 E92 328i xDrive - Deep Sea Blue | '07 E92 328xi - Space Gray)
Old 06-12-2014, 06:06 PM
Colossus Colossus is offline
Mein Auto: 2007 BMW 328i
I have a 2007 328i with sport package and mine takes:
225/40-18 Front
255/35-18 Rear
That's what came on it (bought used) and that's what tirerack says should be on it.
Old 06-12-2014, 07:27 PM
Pilgrim's Avatar
Pilgrim Pilgrim is offline
Car guy since 1968
Mein Auto: 2008 E91 328xi Sportwagon
You need to understand tire sizes to know what you're doing. Please read and understand this: http://www.justtires.com/content/con...eName=TireSize
The tires are only one part of the system. The width and offset of the wheels may be different between the front and back. Hopefully someone here can comment about whether that's the case on your car. Putting the wrong width tire on a wheel can also create problems.
1983 Datsun 280ZX Turbo
2000 Jeep Grand Cherokee
2008 BMW E91 328xi Sportswagon
2009 BMW E92 328ix Coupe
