Old 06-10-2014, 10:58 PM
israelsanchez77 israelsanchez77 is offline
Mein Auto: 2008 BMW 328i Coupe
Angry Clicking sound! Please Help!!
I have a 2008 328i manual coupe with 62,000 miles. My BMW recently starting making this clicking sound when i take off or reverse from a dead stop. It appears that the issue occurred after we had a snow day in my town and my car got stuck. The sound seems to be coming from the left rear axel/tire area. I have linked a video in which you can hear the clicking sound. Please let me know what may be causing the issue.
_a_
Old 06-11-2014, 03:28 PM
fdriller9 fdriller9 is online now
Mein Auto: '06 AW 330xi
Maybe CV joints?
Old 06-11-2014, 04:35 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
Have you checked for rocks or small pebbles in the brake shield(s)?
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts
BMWCCA #453648
Old 06-11-2014, 04:41 PM
Banned
Mein Auto: 2007-335 HTC
how about removing the wheel and looking around, put the car in neutral and spin the rotor and just maybe you will see something that loose, Have you done brake work lately? Loose caliper?
pull the caliper and rotor off check the Emergency brake, there are small brake shoes with spring clips, could be something in there,
if you cant do it take it to a shop have them pull the wheel and rotor
Last edited by hondo402000; 06-11-2014 at 04:42 PM. Reason: left out some important words
Old 06-11-2014, 08:22 PM
thanks for the replies! I will look into removing the wheels this weekend and check to see if there is anything I can spot.
Old 06-12-2014, 05:14 AM
Banned
take photos too and post them
axel, clicking, issue, noise, rear, tire
