Does not reverse......Problems - Bimmerfest - BMW Forums
Old 06-11-2014, 07:49 AM
Yogi_Bear Yogi_Bear is offline
Mein Auto: 2007 328 XI
I own a 2007 328XI Sedan with 178, 000 KM and it does not reverse. I brought it to the dealership to see what is the problem. Has anyone else had this problem? What is the cause?
Old 06-11-2014, 08:20 AM
Mein Auto: '06 AW 330xi
It's probably the shift cables. I've had a couple friends with this issue.
Old 06-11-2014, 09:55 AM
BashedBarrique's Avatar
BashedBarrique BashedBarrique is offline
Mein Auto: 2006 325i
Is it a manual or automatic transmission?
Old 06-11-2014, 11:28 AM
It is an automatic transmission.
Old 06-11-2014, 04:32 PM
floydarogers's Avatar
Pedant and Curmudgeon
There are no cables in the F3x (or E9x for that matter). The controls are all electronic.
Old 06-11-2014, 04:34 PM
Older (E46) BMWs with GM transmissions had a notorious "no reverse" problem where the reverse gear/drum would prematurely fail. Probably the same thing, just not premature.
Old 06-11-2014, 04:35 PM
Banned
Mein Auto: 2007-335 HTC
well if you took it to the dealer why are you asking here, tell us what the dealer found!
Old 06-11-2014, 06:17 PM
Then explain this...
I termed it incorrectly but this is a mechanical linkage that selects forward and reverse gears.
https://wiki.bentleypublishers.com/d...rod,+replacing
Another common problem with the E9x auto trans is the gear shift assembly wiring. The repeated heat cycles and vibrations crack the wire insulation and short the wires together. However, this normally causes a lose of sport mode and manual mode.
Old 06-11-2014, 06:20 PM
And there is an actual cable as well
Old 06-11-2014, 07:34 PM
Guess I was thinking too much about my wife's new F30, which doesn't have one.
Old 06-12-2014, 12:39 AM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
Reverse brake bands usually located in the front near the TQ may need replaced. $5.00 parts but $$$$ to take out and replace.
Old 06-12-2014, 05:01 AM
Banned
you might as well get a new transmission, the Dealer wont repair them, they just replace them
Old 06-12-2014, 07:26 AM
lol that's why you don't use the dealership.
Find a good indy shop in your area to do this work:
www.bimmershops.com
Old 06-13-2014, 05:37 PM
Just got the car back from the dealership. The gear selector valve in transmission was broken. So they replaced the gear selector valve, pan gasket, oil and sealing sleeve. Parts, labour and tax, all amounted to $782. (total labour hours indicated was 5).
Old 06-13-2014, 08:47 PM
Good deal! It costs half that just for the oil drain/replacement.
