Old 06-11-2014, 07:50 AM
joeroc321 joeroc321 is offline
Mein Auto:
Paddle shifters removal.
Does any one know if removing the paddle shifters from an '08 328 is a big deal. They came with the car and we really don't use them. They're sort f right where I'd like to grab the wheel spoke while driving.
Old 06-11-2014, 08:01 AM
Mein Auto: '06 AW 330xi
No just remove them. You should have them coded off but it won't give an error or anything if they aren't plugged in
Old 06-11-2014, 11:13 AM
Mein Auto:
Coded off? Plz explain. Thanks!
Old 06-11-2014, 02:09 PM
Yes turned off so the car knows they are not installed.
You can read up in the coding section or on bmwcoding.com
Old 06-11-2014, 07:37 PM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
Ya don't worry about coding you won't get any errors.
Just disconnect the battery pop out the airbag and then you can remove the 2 screw that hold in paddles , unplug and remove and put the airbag back.
FYI, don't close your trunk after you disconnect the battery unless you can open your trunk with the metal key, not all cars have a manual release.
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
Old 06-11-2014, 10:38 PM
SpeedyE SpeedyE is offline
Mein Auto: 2011/335i
2011 335i Sport/Premium/cold. Black-on-Black, Jack I LOVE this frickin' car!!!!
2007 Suzuki GSXR1000 WERA/CCS SS-spec race bike
Old 06-13-2014, 02:28 PM
Mein Auto:
Originally Posted by SpeedyE View Post
What am I looking at here?
